07-26-2013, 09:39 AM | #1 |
Rock Crawler Join Date: Nov 2011 Location: Omaha, Nebraska
| bec problem help
Ok I am having some issues with my cc bec and don't know what. When I have it hooked up and red wire from esc removed from plug, the truck sitting on the ground and I pull the throttle it lurches back and forth as it slowly inches forward, but when I pick it up and pull the throttle no lurching or anything just smooth spinning of everything. And when I remove the bec and reinsert the red wire from esc everything works perfectly. What is the problem? How do I fix it? I'm so confused. Thanks in advance, Kenneth |
07-26-2013, 10:27 AM | #2 |
Quarry Creeper Join Date: Mar 2010 Location: Yay Area
| Re: bec problem help
Sorry if this is an obvious question but do you have the red/black wires on the BEC soldered to the batt plugs on the ESC? Did you cut the red wire off of the ESC or did you pull it out of the RJ connector?
07-26-2013, 10:31 AM | #3 |
| Re: bec problem help Red/black wires were soldered. Pulled red wire out of connector.
07-28-2013, 03:33 PM | #4 |
Anybody knows what's wrong?
07-28-2013, 04:07 PM | #5 |
Rock Crawler Join Date: Oct 2012 Location: Trail B.C.
Whats the voltage of the BEC set at? I believe they come set at 5 volts. 6 volts is preferred nowadays. Perhaps the voltage is already set higher than 6 and your receiver will not handle more than 6. |
07-28-2013, 04:21 PM | #6 |
RCC Addict Join Date: Mar 2009 Location: Chilton
Pics of it wired up would help. But as of the moment I would say a bad bec something hooked up wrong or like what has already been said incorrect voltage. Do you have a castle link to program it to 6v?
07-28-2013, 11:32 PM | #7 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
what esc? If castle, I had a similar issue and it was in the firmware. Don't ask me why, but rolled it back to the oldest and ended all my issues. |
07-29-2013, 07:14 AM | #8 | ||
| Re: bec problem help Quote:
I am using a cc sv2 | ||
07-29-2013, 07:30 AM | #9 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
| Re: bec problem help |
07-29-2013, 08:37 AM | #10 |
07-29-2013, 09:07 AM | #11 |
Will do. Can I find firmware on castle's site?
07-29-2013, 09:14 AM | #12 |
07-29-2013, 01:56 PM | #13 |
bec problem help - Similar Threads | ||||
Cc bec problem | 509hooligan | Axial Wraith | 5 | 05-04-2013 12:14 PM |
Problem with Tekin RS system in my LCC, will a BEC fix my problem? | rcboy514 | Electronics | 3 | 01-12-2012 05:55 PM |
cc bec problem | DyrtyByrd | Electronics | 6 | 06-08-2010 11:00 AM |
Is there a problem with my cc bec? | jordi555 | Electronics | 6 | 09-01-2009 11:35 AM |
Problem with my CC BEC - HELP!! | swell searcher | Electronics | 1 | 01-05-2009 09:50 AM |
