07-29-2013, 01:51 AM | #1 |
Rock Stacker Join Date: Sep 2009 Location: Italy
| Micro pro + sidewinder
Hi, I wanted to know your opinion, if it's possible use for my xr10 1 sidewinder micro and one micro pro, because i've only one of both.. |
07-29-2013, 03:02 AM | #2 |
Pebble Pounder Join Date: Apr 2012 Location: Brisbane, Australia
| Re: Micro pro + sidewinder
I don't see why not, I'm just not sure wether they may not run the motors at the same speed? But then again if u set them up with your tx travel they should work the same, no harm in trying
07-29-2013, 03:48 AM | #3 |
ah..the motros are 2 novak 55T, and about the bec?I use a hitec 7955tg
07-29-2013, 05:25 AM | #4 |
They will work (I've done it) but they may be a little different. If you have a Castle Link, set both firmwares to the same (I like V1.2, use the same settings & calibrate them. |
07-29-2013, 06:00 AM | #5 |
| Re: Micro pro + sidewinder Yes i've the castle link. Ok i find te 1.28v. of firmware in internet?The only difference is micro pro 35A micro sid. 30A?
07-29-2013, 12:05 PM | #6 |
07-29-2013, 06:47 PM | #7 |
There are always slight differences between parts. Using 2 different model ESC's may yield different reactions in the motors. It may be minor, but it's still there. Using 2 CC ESC's with the same firmware & settings should make them close, close enough to run & have fun with. |
07-29-2013, 07:02 PM | #8 |
I was under the impression that they were the same esc. The pro just has a heat sink and and case.
07-30-2013, 02:25 AM | #9 |
RCC Addict Join Date: Dec 2006 Location: Oak Ridge, TN
| Re: Micro pro + sidewinder |
08-06-2013, 08:16 AM | #10 |
Offtopic, It's possible using 2 esc with proportional dig with dx3r?
08-07-2013, 08:24 PM | #11 |
Rock Crawler Join Date: Aug 2011 Location: Perth west oz
Only with wannamix adapter I think.
Micro pro + sidewinder - Similar Threads | ||||
Mamba Micro Pro vs Sidewinder Micro | strawb | Electronics | 42 | 01-29-2015 07:24 PM |
Sidewinder micro vs Mamba micro pro | Mr. Ed | Losi Mini-Rock Crawler | 26 | 03-05-2009 06:14 PM |
