Thread: CC bec kill 7950th
Old 07-29-2013, 02:23 AM   #1
Default CC bec kill 7950th
hi folks,
I've had an issue on my crawler, my bec was setted to 7.0v to feed my 7950th and few months later my 7950th stop working, very hot : burned.
I checked my bec, impossible to get it dialed with castle link to check output voltage. I checked with a voltmeter : 12.0v output voltage from the bec
Bec has fried and then burn my servo ?
Is there anyone having the same trouble ?
Thanks
Bergm@n is offline   Reply With Quote
Old 07-29-2013, 03:07 AM   #2
Default Re: CC bec kill 7950th
Hi, I have burnt a hitec out on 6v from cc 10a bec, I changed the servo and bec at the same time, I'll have to test the old bec and let u know but the new 7950 and cc bec have been running 7.4v for over eight months now with no probs
sfpumps is offline   Reply With Quote
Old 07-29-2013, 03:11 AM   #3
thanks !
it's very strange and I'm wondering how to prevent a cc bec frying? cause you can't see it's fried and then it kills your expensive servo
Old 07-29-2013, 05:27 AM   #4
I had a CC 10A BEC die, it went to full pack voltage. It was an older style one though (before the large external cap).
Send the servo back to HiTec, they will likely repair it.
Charlie-III is offline   Reply With Quote
Old 07-29-2013, 05:29 AM   #5
Thanks for the heads up as I just bumped up the voltage on my CCbec from 6.0v to 7.4v feeding my Hitec 7950th. Yesterday I was driving my Wraith fairly hard and checked my servo after about 20 min. and it was very hot. It was 88 degrees out and I didn't feel that was hot enough to make a difference. I guess I'll check the voltage from the bec and see what it reads and make adjustments accordingly. Also this is the newer bec with the larger cap.
KRAWL is offline   Reply With Quote
Old 07-29-2013, 06:34 AM   #6
Yep I had a Bec take out 2 Jr 8411 and a gearhead light bar before I figured out my Bec was sending 11.1 volts out .
801RYAN is offline   Reply With Quote
Old 07-29-2013, 06:36 AM   #7
wow I'm not alone
Old 07-29-2013, 07:30 AM   #8
Hey guys, what CCbec are you using, the old or new model? I know Charlie-III said he ran the older model. Just curious and trying to narrow down the problem for future reference.
Old 07-29-2013, 07:33 AM   #9
I think it was the old one, have you got any pix to see the differences?
thx
Old 07-29-2013, 07:38 AM   #10
Both of my og cc becs work flawlessly.
Calderwood is offline   Reply With Quote
Old 07-29-2013, 08:05 AM   #11
I just had a brand new Castle bec do that. It was set at 7.4 but was letting 12v through.
My steering was kick ass for about five minutes
FRIZZLEFRY is offline   Reply With Quote
Old 07-29-2013, 08:06 AM   #12
All those servo burnt are Castle fault, is there anyway to get it taken into account?
Old 07-29-2013, 08:10 AM   #13
thx
Hey Bergm@n, Not with my rig now, but the new one has a LARGE cap on the power input side.
Old 07-29-2013, 08:16 AM   #14
thx
Old
New
Old 07-29-2013, 08:19 AM   #15
Thanks Nigels World for the pix.
Old 07-29-2013, 08:30 AM   #16
Old 07-29-2013, 01:30 PM   #17
I want to say mine was the new style I'll double check when I get home....
Old 07-29-2013, 05:04 PM   #18
Mine that crapped out was the new model.
Old 07-29-2013, 05:13 PM   #19
thanks !
Exactly why I am running a 2s LiFe instead of a BEC.
Dostradamas is offline   Reply With Quote
Old 07-29-2013, 06:31 PM   #20
There's a lot of talk on another forum (RCGroups) about the newer CC 10A BEC's having problems. I have at least 5 of them (newer style) and so far they have been OK.
road_rascal is offline   Reply With Quote
CC bec kill 7950th - Similar Threads
Guns don't kill people, people kill people. Obama's solution to end gun violence... GySgt Hartman Chit Chat 166 01-21-2013 07:11 PM
Hitech 7950TH servo/CC BEC issue DiggyStyle Electronics 8 10-15-2011 04:30 PM
Hitec HS-7950TH servos CC BEC PRO no 7.4v setting Irishchamp Electronics 26 01-26-2010 02:20 PM
