07-31-2013, 01:03 AM | #1 |
Quarry Creeper Join Date: Oct 2010 Location: Land of the Cactus
| Hitec 7950 front case slop
Are there other people having the issue with the front case of there 7950 wearing out and developing alot of slop? I have now replaced my front case atleast 3-4 times in the last year. Wandering if anyone knows if an aluminum front case is made for the 7950?
07-31-2013, 03:37 AM | #2 |
Rock Crawler Join Date: May 2012 Location: Australia
| Re: Hitec 7950 front case slop
Is the slop in the servo output shaft? I found that myn7980 developed a heap of play. When I looked into it, the plate inside, the one that goes into the inside of the out put gear. From where the pot of the servo is. I found that the ring had snapped of and was inside the gear this causing alot of play. |
07-31-2013, 04:58 AM | #3 |
Pebble Pounder Join Date: Apr 2010 Location: Wilmington
| Re: Hitec 7950 front case slop Hitec 7950 possible center case Mod, time will tell...... Check my fix. Seems to work. Hope it helps. |
07-31-2013, 06:49 AM | #4 | |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| Re: Hitec 7950 front case slop Quote:
x2 looked at this few weeks back. Looks like good fix | |
07-31-2013, 10:03 AM | #5 | |
Hitec 7950 front case slop - Similar Threads | ||||
Hitec 7950 possible center case Mod, time will tell...... | LuckyDevil | Electronics | 13 | 11-08-2013 03:15 PM |
Hitec 7950 | flip5513 | Electronics | 5 | 01-20-2010 08:26 PM |
