10-14-2006, 04:35 PM | #41 |
Quarry Creeper Join Date: Jun 2005 Location: Flagstaff
I'm going to have to keep an eye on this set up. Good work.
10-14-2006, 06:36 PM | #42 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
Keep chuggin'. |
10-15-2006, 11:31 AM | #43 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
A few design changes, nothing major, the master cylinder will run longways with the servo and the teeth on the rack will be shifted to one side to make the cylinder fit the shape of the servo to take up less room, also the mounts for the axle will be in a bta setup as aposed to in the front.
10-15-2006, 11:48 AM | #44 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
who makes the cylinders? ive tried doing web searchs on mini and micro hydraulics and cylinders but havnt found much of anything. better keywords i can use?
10-26-2006, 09:40 PM | #45 |
Well I finally got my cylinders today!! The bad part is I left them at work so no pictures. I would tell you were I got them but I don't even know, I just told one of the engineers at work what I wanted and he ordered it for me. I will ask him tommorrow, I can say that they are sweet looking, shinny aluminum, but I think they are going to be too long. I ordered 1.5" stroke but I think I will send them back for some 1" stroke ones. As far as serching for them, I guess I can let the cat out of the bag, they are not hydrolic cylinders, they are air cylinders. But I have been reasured that they will work with glycerin just fine. If they can hold something as thin as air they will hold liquid. Pics tommorow I promise!!! |
10-26-2006, 09:40 PM | #46 |
Oh yeah, I still haven't recieved the rack or the pinion gears either.
10-26-2006, 09:42 PM | #47 |
Sweet. 1.5" stroke is a good bit...you'll have plenty of travel I think the ones I used to get full travel with the stock bump stops on the knuckles had a 25mm stroke. |
10-26-2006, 09:47 PM | #48 |
Yeah, I'm definatly going to get the 1" stroke, The cylinder is double ended and the ends are almost as long as a clod tierod so there would be no room for rod ends with the cylinders I got today. They look good on the axle though, there about as big around as a AA battery.
10-26-2006, 09:57 PM | #49 |
I've got an easy way to mount the cylinders that you'll be using on the axles. Attach a sheet of alum to the axle between the knuckles. Attach one end of the cylinder to the top of the knuckle, then move the knuckle to its steering limit when the cylinder is extended. Make sure the cylinder is extended and put a Sharpie through the eye of the cylinder at the axle end. Swing the cylinder in an arc while keeping the knuckle at full travel and the cylinder at full extension. Then move the knuckle in, retract the cylinder, and draw another arc. The intersection of the two arcs will be the mounting point for the axle end of the cylinder. Then repeat the process for the other side. No measurements...no headaches. Last edited by JasonInAugusta; 10-26-2006 at 09:59 PM. |
10-27-2006, 03:12 PM | #50 |
Well as promised here are the cylinders, I will use these for the master cylinders, I have ordered some 1" stroke cylinders for the axles.
10-27-2006, 03:26 PM | #51 |
Rock Crawler Join Date: Jan 2005 Location: Bethlehem, GA
They look pretty wide for a 10th scale truck. How does it compare to your truck?
10-27-2006, 03:46 PM | #52 |
Yes I know its to wide, That is the master cylinder, I have some 1 inch stroke cylinders on order.
10-27-2006, 04:23 PM | #53 |
Lookin good Kamikaze. Your theory looks to be sound, it'll be cool to see if it works out. |
11-02-2006, 06:43 PM | #54 |
Quarry Creeper Join Date: Dec 2005 Location: Winston Salem
Bump for update
11-02-2006, 11:05 PM | #55 |
Release your anger.. Join Date: Oct 2006 Location: North American Union
i don't know about you guys i think this should be a sticky
11-03-2006, 04:07 PM | #56 |
Only if it works!!!!! I still havent proved anything, exept that I can overcomplicate an already complicated sport.
11-03-2006, 04:59 PM | #57 | |
11-03-2006, 08:10 PM | #58 |
Rock Crawler Join Date: Apr 2006 Location: louisville
its not a bad idea but to me theres too many moving parts easyer to break i keep everything simple
11-04-2006, 11:13 PM | #59 |
Pebble Pounder Join Date: Sep 2006 Location: Medford Oregon
The idea is sound I think the hadest part is gona be the R&P set-up. If U can get the mesh right, and have a good mounting sys. to keep the mesh right................. If U can work it out I'd be interested in a sys. for my truck |
11-04-2006, 11:23 PM | #60 |
I wanna be Dave Join Date: Sep 2005 Location: Dirty South
I know Kamikaze has not givin' up on it . we where out today beat on our rig's . something got broke he opened up his pitbox and said hmmmmmmm "I need to get to work on this" . I have seen most of the parts looks like it might just work . we shall see I guess .
