Thread: Trying to save a really unballanced lipo
Old 08-08-2013, 11:22 PM   #1
Default Trying to save a really unballanced lipo
I was working on my Trophy Wraith and it was going a little nuts. I tried charging the battery and found the issue. 4.2 , 3.2 , 2.2. I would say a little off. So after several hours on my balancer I decided to try another approach. Checking the voltage I found the highest cell and connected my trusty Brood 45t handwound.
So after about an hour of running and the voltage only dropping a little, I decided to try and speed things up. Into a bowl of water. If they break them in with water maybe I can wash this one out ( again first time it has EVER been cleaned. I might have used air to blow it out, but thats it). First shot in the bowl.
Background on this motor. It was the first high end motor. Purchased around 2008. Never once has it been cleaned, turned, had brushes, oiled, or even looked at. It just runs. It had seen life in my Berg with 4s, and then in my super with 4s. She keep running. I hope EddieO does not see this, i am gonna try and send it back and claim a warranty repair.
After about 6 minutes.
The voltage is down enough to put it back on the charger and see what happens. But think the moral of the story would be how filthy the motor was and how well she kept working. Now that it is clean, I would say almost new, I might put it back into the Berg when it gets rebuilt the night before Nationals.
The Violator is offline   Reply With Quote
Old 08-08-2013, 11:42 PM   #2
Default Re: Trying to save a really unballanced lipo
God just killed a kitten.....I am sure of it.
Later EddieO
EddieO is offline   Reply With Quote
Old 08-08-2013, 11:43 PM   #3
I may be wrong here, but I don't think that's dirt your looking at. I think it's the graphite from the brushes.
klabeaume is offline   Reply With Quote
Old 08-08-2013, 11:46 PM   #4
Later EddieO
So your saying it would NOT be covered under warranty?
I know its not dirt, but there had to have been 1/2 an ounce of copper in the bottom of the bowl. I should have taken a picture it that. completely covered in copper.
Old 08-09-2013, 12:36 AM   #5
No, but I can be bribed with corona to fix motors at nats.
Later EddieO
Old 08-09-2013, 12:45 AM   #6
You should recycle all that copper.
You should really put the battery in that lipo sack instead of setting the motor on it.
Sent from my PG86100 using Tapatalk 2
z50king is offline   Reply With Quote
Old 08-09-2013, 03:07 AM   #7
Proverbial threadkiller
Trubble's Avatar
When I got my LiPo's, one of the four packs was a little off. I soldered some short pins (sections of paperclip, I think) to an old battery lead and charged each cell individually through the balance tap. That one's now my go-to pack.
Of course, charging three individual cells (even at 2C) wouldn't save you much time over the setup you've got going. Carry on, I guess.
Congrats on finding a new motor in your cereal bowl.
They don't include kewl prizes like that in oatmeal boxes, sadly.
Trubble is offline   Reply With Quote
Old 08-09-2013, 10:42 AM   #8
When I end up with a unbalanced lipo, I bump it on NiMH setting for 30 seconds and check it. And do it again till the lowest cell is up to 3v or so and then balance an charge.
winnerone23 is offline   Reply With Quote
Old 08-09-2013, 10:51 AM   #9
once a cell drops bellow 3v i usually just NiMh charge it over 3 and then balance it, but they dont last too long after that
winner is offline   Reply With Quote
Old 08-09-2013, 11:00 AM   #10
i plugged mine in without balancer in and it went back up and i pluged the balancer back in to do normal charge
Ohioskills is offline   Reply With Quote
Trying to save a really unballanced lipo - Similar Threads
save of the day stanmondz General Crawlers 0 04-15-2012 08:54 PM
Can I Save This Lipo? alexchen86 Electronics 4 11-03-2011 09:45 AM
Save the Whales Hylux Chit Chat 18 01-07-2008 04:51 PM
Can I Save It NoblesvilleKid Paint and Body 14 07-04-2007 12:01 AM
how much should i save up snook Chit Chat 3 12-08-2006 09:49 AM
