08-11-2013, 08:16 PM | #1 |
Rock Stacker Join Date: Jan 2012 Location: Kingsport
| The new Futaba 4PLS dual esc programming issues
Hey guys, Just wanted to find out if any of you using the new 4pls radio is having issues setting up the dual esc's for front and rear dig? I upgraded from a 4pl to the 4pls and when i go through the programing to setup the dual esc option for front and rear dig the DT4 switch will not move the arrow on the screen to the front dig, 4 wheel and rear dig. My DT4 switch works with other settings such as rate so i know its not the switch. I called futaba about this and they had me walk them through how i set it up to make sure i was doing it correctly. The guy put me on hold for about 15 mins and when he came back he told me that none of the 4pls's in their lab would do this either. He told me i would be receiving a call back then they figure this out but havent heard back from them in 4 days now. |
08-12-2013, 09:41 AM | #2 |
RCC Addict Join Date: Nov 2007 Location: E.T.R.C.
| Re: The new Futaba 4PLS dual esc programming issues
My 4pls dt4 switch works fine for front dig rear burn |
08-12-2013, 06:39 PM | #3 |
Update: Just heard back from Futaba about this issue. The programming on the 4pls is different than the 4pl. The DT4 switch or whichever switch you set for dig should be set to ESC-MD and 3pos in order for dig to work. |
03-06-2014, 09:28 PM | #4 |
Quarry Creeper Join Date: Nov 2011 Location: dark corner
Thanks you just helped me out big time
The new Futaba 4PLS dual esc programming issues - Similar Threads | ||||
Futaba 4PLS in Stock | RPP Hobby | RPP Hobby | 0 | 07-08-2013 04:57 PM |
Futaba 4PLS | SuperRoo | Electronics | 3 | 03-23-2013 07:43 PM |
Novak M2 dig ESC and Futaba 4PL programming | asian195 | Electronics | 7 | 08-11-2012 11:15 AM |
4 pl with dual esc programming issues!!! | rockbender | Electronics | 9 | 04-15-2012 08:18 AM |
Futaba 9CHP setup for dual steering, dual esc | duartev | Electronics | 5 | 06-07-2009 08:58 AM |
