08-12-2013, 05:08 PM | #1 |
Newbie Join Date: Aug 2013 Location: euless
| lipo's
Can you run lipo battery's on a brushed motor? If so, can you expect more power and speed from the truck?
08-12-2013, 05:14 PM | #2 |
Quarry Creeper Join Date: Feb 2013 Location: hawkins
| Re: lipo's
yes yes
08-12-2013, 05:24 PM | #3 |
Rock Crawler Join Date: May 2008 Location: At the corner of Bedlam and Squalor.
I'll back that with a hell yeah.
08-12-2013, 05:55 PM | #4 |
| Re: lipo's |
08-12-2013, 09:17 PM | #5 |
Rock Crawler Join Date: Oct 2012 Location: Casper
| Re: lipo's
Make sure your ESC is compatible. ie: Has a LiPo-safe voltage cut-off.
08-12-2013, 10:30 PM | #6 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| Re: lipo's |
08-13-2013, 07:02 AM | #7 |
| Re: lipo's
So you are saying there is a chance. How do I know if the esc can run lipo? I am running a rooster crawler that is about four years old. |
08-13-2013, 07:09 AM | #8 |
Rock Stacker Join Date: May 2012 Location: Walker
| Re: lipo's
The rooster should be good to go, However you will need to set the cutoff. Its in the instruction sheet. If you need it I can look at mine this evening. Hank
08-13-2013, 09:44 AM | #9 |
Quarry Creeper Join Date: Mar 2012 Location: Roseburg
You can run lipo on any ESC even if it doesnt have a LVC. As long as your lipo does not exceed the maximum voltage for the ESC. Run a low voltage alarm if your ESC does not have a LVC. A LVA will beep loud enough for everyone to hear it. Sent from my Transformer TF101 using Tapatalk 4 |
08-13-2013, 09:50 AM | #10 |
RCC Addict Join Date: Jul 2008 Location: Fox Valley WI
| Re: lipo's
You should be able to find all the specs on that ESC on Novak's website. I believe they still have the original user guides for discontinued products as well.
08-13-2013, 02:47 PM | #11 |
| Re: lipo's
Just a quick note, the rooster will only run 8.6 volts or so. The magic smoke comes out otherwise. Hank
08-13-2013, 03:17 PM | #12 |
| Re: lipo's
thanks for the help, I found the instructions online, so now I just need to buy a lipo. The manuel said 2s max, so sounds like a 2s for me.
08-13-2013, 09:06 PM | #13 |
| Re: lipo's |
lipo's - Similar Threads | ||||
anyone try these lipo's ?? | Nish | Electronics | 0 | 06-19-2008 05:08 PM |
Lipo's | 01XJ | Electronics | 5 | 03-15-2008 02:20 AM |
