08-13-2013, 11:51 AM | #1 |
Pebble Pounder Join Date: Nov 2009 Location: coalmont
| Dewalt drill motors
How do I wire a Dewalt drill motor up to run on lipo? Any help appreciated .
08-13-2013, 12:05 PM | #2 |
| Re: Dewalt drill motors
Wire it to the lipo combatable esc just like you would any other brushed motor. It's just two wires.
08-13-2013, 12:43 PM | #3 |
Will it work on a side winder
08-13-2013, 01:06 PM | #4 |
RCC Addict Join Date: Oct 2006 Location: crawlifornia
It's two wires right, pos & neg. same as any other motor right? right? ? Lipo + ESC + Dewalt motor... any questions? take pics though please I would guess this dewalt motor to have a ton of torque _______________________________________ Last edited by rockhugger; 08-13-2013 at 01:53 PM. |
08-13-2013, 01:26 PM | #5 |
| Re: Dewalt drill motors |
08-13-2013, 09:53 PM | #6 |
01-22-2014, 11:20 PM | #7 |
Newbie Join Date: Jan 2014 Location: Albuquerque
I just finished an install on my wraith. I used the motor out of my 12v dewalt drill with the adjustable chuck. You need a torque bit to take the drill apart if you go this way. It is replacing a traxxas titan 21t that took a sh!t. First I had to cut the pinion gear off the shaft. Its a 48 pitch and a 16t but it doesn't line up correctly on the spur gear. The gear is pressed on and won't come off by prying it, I used a dremel with a cut off wheel and scored two opposite sides and then cut it with wire cutters. It breaks easily Next I ground a flat spot on the shaft with the dremel again Then I soldered my new leads with deans plug Then add a new pinion gear and hooked all my sh!t back up and its good to go. the test run was good. Didn't have to do anything else. It took about half an hour and was pretty easy to do. POWER- I am running a tekin fxr-pro, 17t pinion, stock spur and mip's This motor has plenty of torque! Instant smile. I was running the traxxas titan 21 that i ran on 2s and i though that set up ran good. Good torque, fast enough for my needs, but it did run a little hot. The DEWALT motor has a lot more torque. I've only driven around a small yard so can't say anything about heat, speed, battery use later. I have only run it on 2s for the test run, but i'll try 3s and update when I get a chance to go out. I'll post pics and vids later as well |
Dewalt drill motors - Similar Threads | ||||
dewalt drill motor in wraith? | 25-5 | Axial Wraith | 4 | 02-02-2015 10:07 AM |
Dewalt motors | teifert2429 | Electronics | 6 | 08-06-2013 10:02 AM |
14.4V Dewalt Brushed Motors... | alexchen86 | Electronics | 0 | 07-24-2012 09:33 PM |
Drill Motors? | MiddleT | Electronics | 6 | 05-03-2009 03:09 PM |
