08-13-2013, 10:53 PM | #1 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
| 3rd channel switch?
I was just curious if I could switch between 2 components (let's say 2 servos) both using one channel but having 2 different uses. Could I do this with a 2 position switch hooked up the rx? How would it be weird? I've seen it done before, but I'm not sure how the guy did it. sent from my crappy phone using tapatalk 2 |
08-14-2013, 06:32 AM | #2 |
| Re: 3rd channel switch?
You could use a SPDT switch (single pole double throw). Signal wire from the RX goes to the switch common (usually the center connection) and then goes out to each device, one to each of the empty connections on the switch. The red & black need to be split and shared between the 2 devices as it comes out of the RX. |
08-14-2013, 09:45 AM | #3 |
Thanks man! sent from my crappy phone using tapatalk 2 |
08-14-2013, 11:28 AM | #4 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
my understanding here is that you want to use the same control inputs to operate two different outputs at different times. Am I correct? Do you want to use it in a remote switching capacity or a manual switch on the car itself? If the answer provided above fixes what you are looking to do, disregard my question here. |
08-14-2013, 12:51 PM | #5 | |
sent from my crappy phone using tapatalk 2 | |
3rd channel switch? - Similar Threads | ||||
3rd channel switch? | smuggl1n | Electronics | 2 | 12-12-2012 06:50 PM |
Can I use this type of Switch for my 3rd Channel | MtnMan210 | Newbie General | 5 | 06-08-2008 05:53 PM |
Rotary Switch for TQ3 3rd Channel? | Trike Kid | Electronics | 0 | 01-18-2006 10:26 PM |
Looking for a switch that turns lights on with 3rd channel | socal2azdezert | Electronics | 2 | 12-19-2004 09:38 AM |
