08-14-2013, 04:27 PM | #1 |
Newbie Join Date: May 2013 Location: port angeles
| tekin fxr or mamba max pro?
i see alot of people using the fxr and a lot of people using the mamba max pro. i would be putting it in a wraith so i want some wheel speed but also torque. i definatly need forward/drag/reverse and just want to know which would be the best and what the downsides to each one are
08-14-2013, 04:33 PM | #2 |
ahhh S^*T Join Date: Mar 2012 Location: in the shop bending metal in Whatcom Co. WA.
| Re: tekin fxr or mamba max pro?
2 different animals all together. I would go MMP for a wraith. if you need to save space and only want to run brushed ever then FXR... very small compared to the MMP. MMP- Brushless OR Brushed, sensored or NOT, adjustable onboard BEC up to 6s lipo, (altho I recomend external BEC always), smooth and reliable. great all around spedo for everything. if you ever want to go 4 pole tekin brushless motor or something your good to go!! FXR- very adjustable without hotwire via TX, SMALL, brushed only, awesome brakes, 3s stock but can run 4s with Cap mod and BEC. |
08-15-2013, 03:11 AM | #3 |
As Jeepster said the MMP is sort of a "Jack of all trades" while the FX-R is brushed motors only. First you need to decide, or at least consider, what type of motor you'll be using and how you'll use it. - If brushless is on the horizon (only recommended for bashing) the MMP is a preferred choice. - For mostly somewhat slow crawling with a brushed motor the FX-R is a great option. - For faster runs with a brushed motor you could consider some third option, like Castle Sidewinder or HH Torquemaster BR-XL. |
08-15-2013, 11:20 AM | #4 |
Rock Stacker Join Date: Mar 2012 Location: longview
Brushless crawl just fine when you use a good 4 pole motor. Volt up and gear down. Plenty smooth
08-15-2013, 11:57 AM | #5 |
I want decent wheel speed. But lots of power and no jittering when going very slow for crawling.i dont want to bash. Im thinking I want brushed just because i need a drag brake and I want to be able to switch between 35t and 55t when on trails or rocks
08-15-2013, 12:10 PM | #6 | |
| Re: tekin fxr or mamba max pro? Quote:
(More than) Lots of power - 4 pole sensored No jittering - 4 pole sensored Drag brake - 4 pole sensored No need to switch between motors - 4 pole sensored | |
08-15-2013, 12:17 PM | #7 |
Alright. so then what motor and esc combo would be best? And with what battery?
08-15-2013, 12:18 PM | #8 |
Rock Crawler Join Date: Jan 2013 Location: Middleburg Florida
MMP. You may eventually want a nice sensored motor in there. MMP does it all man. I currently have 4 MMP's looking for a 5th right now. The only issue I have had is sand in the on/off switch.
08-15-2013, 12:21 PM | #9 | |
Motor - pro4 or 3656sd or roc 412 Battery - any 3s capable of delivering 100a. Last edited by Calderwood; 08-15-2013 at 01:11 PM. | |
08-15-2013, 12:31 PM | #10 |
Ive been hearing better things about the pro4 so prob that on 3s
08-15-2013, 12:54 PM | #11 |
What kv?
08-15-2013, 12:58 PM | #12 |
| Re: tekin fxr or mamba max pro? |
08-15-2013, 01:06 PM | #13 |
How about a ROC 412 3100KV? Mine runs like a champ! smooth, plenty of torque and fits easily.
08-15-2013, 01:13 PM | #14 |
08-15-2013, 01:13 PM | #15 |
I dont want anything too fast to where I break shit every run Though! Haha
08-15-2013, 01:16 PM | #16 |
08-15-2013, 01:28 PM | #17 |
08-16-2013, 05:00 AM | #18 |
I'd consider Holmes Revolver S 540 as well. Why stick to 4-pole when you can have 14-pole? Less motor speed but more torque, so it can use a larger pinion. |
08-16-2013, 10:24 AM | #19 |
I think what ill be doing is mmp with the roc 412 3100kv on 3s. Does that all sound about right? Haha
08-16-2013, 10:36 AM | #20 |
Perfect. Mine is super smooth and make sure you get yourself a 4S battery too. It's incredible on 4S trust me.
tekin fxr or mamba max pro? - Similar Threads | ||||
Mamba Max , Tekin FXR or Tekin FXR PRO? | TheHeadHunter | Electronics | 21 | 06-21-2012 08:15 AM |
mamba max vs tekin fxr | James003 | Electronics | 14 | 08-13-2010 02:07 AM |
