08-17-2013, 09:26 PM | #1 |
Newbie Join Date: Jul 2013 Location: Corvallis
| MMP / Tekin ROC 412 settings?
I was wondering what settings people are running in their rigs. Axial Wraith (9 lbs) 3S Lipo 11/54 pinion/spur HD stock front, HD UD rear I am running 10 deg timing in "smart" mode. Thinking about switching to "sensor only" and running 0 deg with CHEAT set to 10 deg. What do you guys think? Any input would be greatly appreciated. Last edited by LucasAutomotive; 08-21-2013 at 05:33 PM. |
08-17-2013, 10:29 PM | #2 |
| Re: MMP / Rekin ROC 412 settings?
I run everything in stock form. Just bump up the Lipo cut off to 3.3v per cell, 75% throttle F&R, 15% drag brake, and crawler reverse unless your using it for bashing, and I always run sensored only with a sensored motor. I never mess with brake and throttle curves either. I'm just not that in to it. The motor in stock form will give you more torque and more speed than you'll really need. See how you like it then play with it and make changes as you see fit.
08-17-2013, 10:45 PM | #3 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
Why do you want to advance the timing? Not necessary for crawling, there would not be any advantage for advanced speed or punch... Unless you are trying to jump a rock or two... |
08-17-2013, 11:15 PM | #4 |
Even at that he could just mess with the punch control and leave the timing alone.
08-17-2013, 11:51 PM | #5 |
If you set the RPM for CHEAT high enough it shouldn't kick in when crawling and should help top speed. Also I have the timing at 10 deg because its the default for the MMP. Just wondering if my thinking is way off. |
08-18-2013, 06:54 AM | #6 |
Rock Crawler Join Date: Oct 2009 Location: Knoxville
The ROC motors are 4 pole motor, they do not handle advance timing very well. There is a thread about them (somewhere, I am on my phone or I'd post the link). There is a discussion about just that thing with ESC set ups and input from Tekin. |
08-18-2013, 08:35 AM | #7 |
| Re: MMP / Rekin ROC 412 settings? Good point! Maybe Ill drop the timing to 0 and leave CHEAT off for now. If you could find that threat I would greatly appreciate it. I have been looking and found no solid info yet.
08-18-2013, 09:05 AM | #8 |
Quarry Creeper Join Date: Feb 2013 Location: hawkins
i run mine with no timming in sens only and set my traction control up to 20% i also use the lowest start setting. my truck runs cool all day
08-18-2013, 09:07 AM | #9 | ||
| Re: MMP / Rekin ROC 412 settings? Quote:
World release, Tekin ROC 412 The first bit of the thread is about the release. Start about page 13 or 14. | ||
08-21-2013, 05:41 PM | #10 |
Thanks for the infomand link Dentonmac. I switched to sensor only mode and my wraith running great. MMP / Tekin ROC 412 3S lipo 11/54 pinion/spur HD standard front HD UD rear 100% throttle 50% reverse 25% drag brake for bashing Sensor only mode without CHEAT Medium power on startup Punch disabled Dead band .100 Auto lipo cutoff Throttle and brake curves left stock |
08-23-2013, 10:13 AM | #11 |
Sweet!
MMP / Rekin ROC 412 settings? - Similar Threads | ||||
MMP / Tekin ROC 412 3100kv settings? | LucasAutomotive | Axial Wraith | 2 | 08-17-2013 09:24 PM |
MMP and Tekin Roc 412 | Onebdgti | Electronics | 0 | 02-23-2013 08:07 AM |
Tekin ROC 412????? | Soulo747 | Electronics | 1 | 12-09-2012 05:18 PM |
