08-19-2013, 10:06 AM | #1 |
Quarry Creeper Join Date: Sep 2012 Location: middle of nowhere
| Did I fry my B1R?
So here's the scoop: I was letting a buddy drive my MRC, about 15 mins in he tells me he can't go forward anymore. He wasn't doing anything I wouldn't do as far as driving and the motor/esc resembled temps that I had encountered before. (Based on feel, I didn't have a temp gun handy.) I let it cool down for a good hour and experienced the same results, I had reverse and full steering but no forward. I might also add that when going in reverse I no longer had drag brake like I did before. When I got home I plugged in my hotwire and double checked my settings. They were slightly different than my notes said they should be so I adjusted them and updated my esc. Nothing changed, still no forward and no drag brake. Steering still working fine as was reverse. I then recalibrated the rx/tx thinking something may have went wrong there, still no change. I plugged in my hot wire again and re-updated the esc...yet again no change. I guess my question is have you guys/gals had anything like this happen? I know the B1Rs aren't the most robust esc and it's probably toast. I just wanted to double check before I decide on my next move...most likely upgrading to a FXR. On this rig I am running a losi insane motor on 2s with a 12t pinion. |
08-19-2013, 10:43 AM | #2 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| Re: Did I fry my B1R?
How old is the motor? Wear wise?
08-19-2013, 07:36 PM | #3 |
The motor was new in January and does not have too much run time on it. Can a motor wear out or malfunction to where it will only move in one direction?
08-19-2013, 07:43 PM | #4 |
| Re: Did I fry my B1R? |
08-20-2013, 09:20 AM | #5 |
08-20-2013, 09:42 AM | #6 | |
| Re: Did I fry my B1R? Quote:
This is the motor you have, correct? | |
08-20-2013, 05:33 PM | #7 | |
Thanks | |
08-20-2013, 06:50 PM | #8 | |
It could, brushes may be worn poorly and be shifting in the hood like Nigel said. Check the brushes and look in on the com to see what it looks like. Also with motor removed hook up a double a battery to it running in both directions and see what it does. | |
08-21-2013, 07:33 PM | #9 |
Yeah when I get a chance I'll pull the motor and brushes. Then I'll hook a volt meter to the esc. I'm hoping the motor is shot, I would rather replace or upgrade the cheap motor. Thanks all!! |
08-21-2013, 09:09 PM | #10 |
No worries, let us know what ya find eh
Did I fry my B1R? - Similar Threads | ||||
Did I fry my FX-R? | micro racer | Electronics | 10 | 07-17-2013 11:41 PM |
What did i fry? | SHOtime | Team Losi Comp Crawler | 6 | 09-22-2012 09:09 PM |
Did I fry my rx or ??? | scoobydann | Electronics | 12 | 08-08-2010 03:19 PM |
Did I fry it | mudboger07 | Newbie General | 5 | 02-05-2008 07:54 AM |
Please help, I don't want to fry anything... | WRMorrison | Electronics | 18 | 12-31-2004 05:50 PM |
