08-19-2013, 09:55 PM | #1 |
Newbie Join Date: Aug 2013 Location: Wenatchee
| External Bec/Battery pack help
So I just swapped out my axial tx and RX for a dx3r and a sr300. When I turned all the way each way it'd shut down and reboot so I had an idea instead of an external bec. I hooked up a nicd 7.2v battery pack in the bind port with an on/off switch. According to the spektrum manual the sr300 can handle anywhere from 3.9v to 15v. I checked the voltage from the ESC to the receiver and it was at 5v. So what ive done is hooked up the 7.2 and the 5.0 and i have no problems when i have the battery pack turned on on also. And i just got done running it for 45 minutes on a 3s with the pack on. So just to run it through all of you to make sure there's no long term effects that I'm not aware of.
08-19-2013, 10:31 PM | #2 |
| Re: External Bec/Battery pack help
If you're going to keep the external battery plugged into the RX, I would remove the red wire from the ESC to the RX, otherwise you'll have 2 power sources feeding the RX which is likely to cause issues.
08-20-2013, 12:07 PM | #3 |
So your saying solely run on the battery pack by disabling the red wire coming off the esc? Its a venom 1200 7.2v by the way.
08-20-2013, 09:43 PM | #4 | |
| Re: External Bec/Battery pack help Quote:
Do not cut the ESC to RX red wire, just remove it from the RX connector and tape it off. | |
08-26-2013, 10:59 AM | #5 |
I joined the Band! Join Date: Aug 2013 Location: The Hills Of VA
Yes you will need to remove red wire..
External Bec/Battery pack help - Similar Threads | ||||
using external BEC & esc's internal BEC.... | slowlearner | Newbie General | 2 | 02-14-2010 01:35 AM |
External Battery Pack | kmrunner | Newbie General | 2 | 01-22-2010 08:05 PM |
Does Hitec 5995/5955 servo need the external/additional battery pack? | xingfuderen | Electronics | 2 | 04-11-2008 12:45 PM |
2215 receiver with external battery pack | Big Ahso | Electronics | 3 | 03-29-2006 08:31 PM |
