08-20-2013, 12:45 AM | #1 |
Rock Crawler Join Date: May 2013 Location: Dallas
| Brushed SV3 won't run
Hey y'all. I hate posting in here but I need some help, maybe I've overlooked something. I have a castle sv3 running a Tamiya 23T brushed motor in my twin hammers. Everything ran great this weekend with no problems, however when I threw a batt in it today I had some trouble. I couldn't get it to drive at first and I never heard the beeps when I turned the SV3 on however I did see the LED's. Since this is the first brushed motor I ran in 5 years I went through all the basics making sure everything was plugged up. I then pulled on the brushes a little and let them snap back to the commutator. This worked for about 20 minutes or so until I had to run in to the house for a sec. When I came back out I had the exact same symptom, the truck wouldn't move any where. I pulled on the brushes again and heard them snap against the comm, I don't want to lube them and attract dust but before I spend 30 minutes pulling this motor out to check it more I want to confirm that I'm on the right path with this. TL DR Castle SV3 with 23t brushed Stopped working, found a stuck brush Stopped working again, don't think brushes are stuck |
08-20-2013, 01:08 AM | #2 |
Rock Crawler Join Date: Dec 2011 Location: Blacksburg
| Re: Brushed SV3 won't run
Sounds like the brushes are worn or the springs are hung and not pushing on the brushes. Or you could have a burnt spot on the comm.
Brushed SV3 won't run - Similar Threads | ||||
Castle sv3 motor limit? For brushed | Bogncrawl | Electronics | 2 | 07-19-2013 07:56 PM |
can i run a brushed motor with a brushless ESC!! | jon1197 | Newbie General | 5 | 01-31-2010 09:00 AM |
Thoughts on what Brushed ESC to run | Rock Hound | Axial AX-10 Scorpion | 9 | 12-22-2008 09:42 PM |
anyone run a mamba maxx with a brushed motor | rockwerks | Electronics | 5 | 09-07-2006 08:31 PM |
