08-21-2013, 03:31 AM | #1 |
Rock Stacker Join Date: Aug 2013 Location: Alabama
| I am a noob.. Need help!!!!
Running brushless setup with MMP and had to rev throttle in radio.. Reverse has twice the power as forward. I can figure it out with trial and error but someone who knows what I need to change please let me know... Thanks!!!!
08-21-2013, 04:11 AM | #2 |
Rock Crawler Join Date: May 2012 Location: Australia
| Re: I am a noob.. Need help!!!!
Swap radio setting back to the other was and swap the wires going to the motor
08-21-2013, 04:20 AM | #3 |
Thanks Bro!!! Have done that and did not work. I reversed it back to norm in the radio and swapped the red and black wires to the motor and all it did was vibrate back and forth. Will get some sleep and hook the MMP to the computer and see if I can change it with Castle link...
08-21-2013, 04:24 AM | #4 |
Calibrate it to the radio aswell.
08-21-2013, 09:08 AM | #5 |
Rock Crawler Join Date: Aug 2011 Location: Perth west oz
What radio? Futaba or other brand. It seems that futaba radio need to run throttle in reverse for most of the ESC. When you pull the throttle (forward) what color LED blink in the ESC? If it is green, then you are fine. If it is red then you should change the radio throttle to the opposite. Then use castle link, and change the motor direction to the opposite so you car go forward when the green light on ESC flashes. you can set the reverse to be 100% too if you want. Also like above mentioned, calibrate your radio to the ESC so at max forward throttle, the green stays on and at max reverse, the red light stays solid. |
08-21-2013, 11:19 AM | #6 | |
| Re: I am a noob.. Need help!!!! Quote:
08-21-2013, 12:22 PM | #7 |
WOOOT!!!! Hooked it up to castle link and reversed the motor with it.... Good to go now.
I am a noob.. Need help!!!! - Similar Threads | ||||
Noob!!! Help!!!! | kjardine | Tamiya Clod Buster | 1 | 07-24-2012 04:54 PM |
noob help | NickGood | Newbie General | 1 | 01-29-2011 08:06 AM |
noob but not | thumper68 | Minnesota | 2 | 03-06-2010 10:38 PM |
another noob ?? | thumper68 | General Scale Talk | 0 | 03-06-2010 07:19 PM |
noob, with noob questions | farmerstoy | General Scale Talk | 12 | 01-14-2010 06:28 PM |
