08-23-2013, 08:24 PM | #1 |
Quarry Creeper Join Date: Dec 2010 Location: Australia
| Novac goat 3s recommendations
hi I have a novac goat 3s with 18.5 motor the throttle is glitching forwards on start of acceleration but not reverse should I cut my losses and get something else or try and fix this one I don't know if this will work "Novak 5626 Glitch Buster Capacitor" ? any ideas or suggestions to a new set up ? thanks Adam |
08-24-2013, 06:47 AM | #2 |
| Re: Novac goat 3s recommendations
We're assuming you calibrated the ESC to the RX? What battery connectors (hopefully NOT Tamiya)? What battery (chemistry, cell count/voltage, "C" rating if LiPO)? "Glitch busters" are a band-aid covering the real issue in my view. |
08-24-2013, 10:05 PM | #3 |
the battery connectors are the deans type the battery's are lipo 1.3 3s 25-50c and I re binded the spectrum dx3r and it was ok on a full charge but when the pack got down to say 50% it started glitching again maybe the batteries are shagged ? or something else does this help to identify it ? Adam |
08-25-2013, 06:28 AM | #4 |
Binding the TX to the RX is one thing, calibrating the ESC to the RX is another. I asked about the recalibration. If it works fine on a fully charged pack, you may have a tired pack. Try it again, then, when it starts acting up, put the pack on the charger and look at the cell voltages. See if you have a low cell. Everything else looks OK. |
08-25-2013, 07:20 AM | #5 |
Rock Crawler Join Date: Oct 2012 Location: Trail B.C.
Are you running a high torque servo? Are you running an external BEC? You may be running into power consumption issues with the servo and internal BEC on the goat. |
08-25-2013, 03:35 PM | #6 |
the servo is a hitec 7955tg and no external bec I think its the battery's now as they are about 2 years old I will get a new one and try it thanks for your replys Adam.. |
08-27-2013, 12:41 PM | #7 |
Quarry Creeper Join Date: Dec 2010 Location: Jacksonville
I think its a novak issue.. my goat3 glittches on every 4th punch.. ex: if you're climbing a hill with a turn and you need to pop around the turn.. you give it 4 trys and on that 4th try i get a glitch! Servo is Novak sa1230sg 3s 1800 15c Castle 5amp BEC.. Novak Balistic 21.5 motor.. but if i lay on the trottle climbing up stuff. it never glitches.. Im living with it. |
08-28-2013, 08:49 AM | #8 |
Quarry Creeper Join Date: Jun 2012 Location: Earth mostly
When I first installed mine I had glitching every so often. Installing the BEC to my servo fixed it. I have the Goat 3s in my Night Crawler, stock radio, 7950 servo with BEC for the servo and a second BEC for the receiver and knock on wood a year and a half and not a single problem.
08-28-2013, 09:10 AM | #9 | |
| Re: Novac goat 3s recommendations Quote:
NOTE: If you ran/run an external BEC to the RX, remove the red wire from the ESC to RX so you don't have 2 power sources feeding the RX. | |
Novac goat 3s recommendations - Similar Threads | ||||
novac m2dig | simpsonkw1 | Newbie General | 0 | 04-14-2013 07:56 AM |
novac | wurster | Electronics | 1 | 11-12-2011 10:55 AM |
novac | wurster | Electronics | 3 | 09-11-2010 06:28 AM |
novac xrs help | JEFFSANTOS | Electronics | 2 | 06-03-2010 10:22 PM |
