08-25-2013, 05:10 PM | #1 |
Quarry Creeper Join Date: Dec 2007 Location: Cap-St-Ignace,Québec,Canada
| Bec
I buy Tekin FX-R esc/35T for my Wheely King.It's better use BEC? |
08-25-2013, 05:50 PM | #2 |
RCC Addict Join Date: Feb 2012 Location: Ca.
| Re: Bec
In my opinion, it depends on your steering servo torque. I run 208 oz torque servos and BRXL's and don't see a need for one . If I was running high torque servos in my rigs I'd wire one up. Just my opinion as I said. Many here will disagree with me.
08-25-2013, 07:16 PM | #3 |
| Re: Bec
I use original servo come with the kit
08-25-2013, 11:21 PM | #4 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| Re: Bec
There is no loss for using a bec..... Best bet is to put one in every rig.
08-25-2013, 11:31 PM | #5 | |
| Re: Bec Quote:
Most ESC's can handle up to ~200inoz on the internal BEC. The Holmes BR-XL's can handle more torque. If running 2S LiPO, you can wire high voltage (HV)/high torque servos direct to battery power although an external BEC is best. | |
08-26-2013, 05:22 AM | #6 |
| Re: Bec
What is the best Bec for my rig?Possible use 2S and 3S lipo.
08-26-2013, 06:43 AM | #7 |
| Re: Bec The most common is a Castle Creations 10A BEC. Supers and some scalers run the CC Pro BEC (basically 2 BEC's in one). The same CC Link can set the voltage in the BEC as well as their ESC's. The CC 10A BEC is all I, and my son, use. |
08-26-2013, 08:07 AM | #8 |
Pebble Pounder Join Date: Mar 2010 Location: Stillwater
| Re: Bec
If your rig is stock with the stock servo, I doubt you'll notice the difference adding an external BEC, other than the $20 hit in your wallet. Now if you upgrade to a high torque servo, they're worth every penny. I've only ran the Castle Creations 10a and the Pro and have been very happy. |
08-26-2013, 08:18 AM | #9 |
I joined the Band! Join Date: Aug 2013 Location: The Hills Of VA
| Re: Bec
I'm running a Hi-tec 8380 servo on a Tekin RX8 with no BEC and no problems.
08-26-2013, 02:44 PM | #10 |
| Re: Bec
sooner or later your stock servo will be toast. get a BEC now , then when you need a servo your already set up.
08-26-2013, 03:11 PM | #11 |
RCC Addict Join Date: Mar 2009 Location: Chilton
| Re: Bec
Yes you need a bec. It helps your esc run cooler and last longer it is programmable to different voltages depending on what servo you run. I have also noticed on some of my friends rigs that it seems to make the battery run longer. I always put a bec on mine before a battery ever gets hooked up. I am not sure how having the bec would make your battery last longer but we all run the same batteries and all of our batteries except mine had to be changed about the same time then one of them added a bec and then his battery out lasted the others like mine so now they have a bec. People might disagree but that is from my experience along with 4 friends I crawl with. |
08-26-2013, 04:06 PM | #12 |
Quarry Creeper Join Date: Mar 2010 Location: Yay Area
| Re: Bec
Get a BEC Get a BEC get a BEC. Oh yes, you need a BEC! |
08-26-2013, 05:44 PM | #13 |
| Re: Bec
Funny how its in the stickies.... But still gets asked 2-3 threads a day. |
08-26-2013, 05:45 PM | #14 |
RCC Addict Join Date: Aug 2011 Location: Elkhart
Get a BEC! Lol Heck for $20 bucks why not? It's a cheap wonderful mod that may SAVE you one day... |
08-26-2013, 08:42 PM | #15 |
Rock Crawler Join Date: May 2008 Location: At the corner of Bedlam and Squalor.
BECs are cheap and very worthwhile. If you're running a single normal-ish servo in a trail/bashing kind of situation, a $5, 5a BEC from Hobbyking will cover it. They use switch mode regulators, so they're very efficient. If you're running a heavy rig, multiple servos or in hard competitive situations, go for the power provided by a Castle 10a. |
09-03-2013, 08:21 PM | #16 |
Pebble Pounder Join Date: Jan 2012 Location: Chino Hills
I recently purchase a Berg. I am going to run 2 HH BRXL mini and a high torque servo. I am also going with a dig set up on my Futaba radio. What BEC should I use and do I need one for each ESC? |
09-03-2013, 09:42 PM | #17 |
| Re: Bec A single CC 10A BEC is all you need. The mini's have an internal BEC to power the RX (so, you only need 1 to power it).
09-03-2013, 10:30 PM | #18 | |
Do you know where I can get instructions on how to wire a dual ESC with one BEC. | |
09-04-2013, 12:15 AM | #19 |
| Re: Bec Bec does not hook to esc. There is however 2 ways to wire them up. One sending power to reciver..... Other way is sending it directly to servo. I'm on my phone out of town so ill let someone else post up a link to the how to for each way.
Bec - Similar Threads | ||||
BRXL+Castle Link+Bec=? How do i set BEC? | crazyorigin | Electronics | 17 | 11-21-2011 03:11 PM |
Built in bec vs. Rooster Crawler bec for glitching | mudking82 | Axial AX-10 Scorpion | 7 | 12-07-2010 08:57 AM |
using external BEC & esc's internal BEC.... | slowlearner | Newbie General | 2 | 02-14-2010 01:35 AM |
Castle BEC & Castle Link - not finding BEC | Locked Up | Electronics | 22 | 12-20-2007 03:37 PM |
Receiver BEC (vs ESC BEC) | sim | Electronics | 7 | 10-13-2005 07:54 PM |
