08-25-2013, 10:38 PM | #1 |
Newbie Join Date: Aug 2013 Location: Bloomfield
| overheating esc
Ok guys I need some help with this I just bought a team tekin combo pack for my Wraith im running a fxr esc with a 35t pro motor on a 2s 5000mah lipo gearing is 87 spur 11 pin no dig unit no drive train upgrades savox single steer servo the prob im running into is after about 15-35 mins of run time (easy low speed crawling on the living room carpet) everytime i make a hard left turn the system gliches. Stutters, stops, shuts down, restarts. But only on a left turn havent noticed it on a right turn. motor and esc are installed correctly, cap is soldered in though there is no BEC installed, i have an extra one so if thats what i need then thats not a problem. Ive looked on the tekin website to see if they recomend a BEC but am unable to find anything on it. What do you think BEC or factory screwed up combo?
08-25-2013, 10:40 PM | #2 |
| Re: overheating esc
BTW I forgot to mention when the glitches happen the motor is room temp but the esc itself is extremly hot
08-25-2013, 11:15 PM | #3 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| Re: overheating esc
Savox servos like to rape a lot of power, with that anything I run I use a external 10 amp bec. Sounds like the glitch part is your lack of a bec.
08-25-2013, 11:43 PM | #4 | |
| Re: overheating esc Quote:
Check steering EPA's, you may be overdriving the servo in one direction, the stalled servo pulls a lot of amps. Since you're running 2S, you can power the servo direct off of battery power. | |
08-27-2013, 09:55 AM | #5 |
| Re: overheating esc
How would I check the steering EPA's and wire the servo directly to the battery? And right now I'm out of town for work but when I get home I'm gonna install the bec I have and see if that helps BTW the radio system I'm running is a spektrum dx3c
08-28-2013, 05:48 AM | #6 |
Rock Stacker Join Date: Jul 2012 Location: Tn
| Re: overheating esc
+1 on above and also check all steering for binding on left turn.
08-28-2013, 09:33 AM | #7 | |
As to "wired direct", several ways, but basic is: Red wire from batt/ESC connection to red wire on servo Black wire from batt/ESC connection to black wire on servo Some solder them together (cut off the wires at the RX plug), others use a servo wire extender and splice that in. It would likely pay to maintain the ground from the servo to the RX. Especially on Spektrum radios. | |
08-28-2013, 09:41 AM | #8 |
Quarry Creeper Join Date: Apr 2013 Location: SE PA
| Re: overheating esc
I used an extension to make a harness. was a 12" extension. cut it 3" from each plug. connected the 2 control wire between the plugs. dabbed liquid tape on the power leads coming from the RX plug. wire the power leads from the servo plug into the 6" left over then connected them directly to the battery leads coming from my esc. ended up cutting about 3" off cause there was to much extra wire. little bit of liquid tape on the connections. wrapped that in some electrical tape then coated that in more liquid tape (was my first harness and non soldered so I was trying to make sure it was sturdy enough to be pulled at. no problems yet. the cheap solar servo still going strong. |
08-28-2013, 11:09 PM | #9 |
| Re: overheating esc
Ok I installed a 10 amp bec seems to be working fine gonna test it some more tomorrow
overheating esc - Similar Threads | ||||
esc overheating problems. | K4G3 | Newbie General | 4 | 02-21-2013 11:42 AM |
Smoke/Overheating from ESC | SinCity | Axial SCX-10 | 6 | 06-14-2010 07:09 AM |
Stock TR ESC overheating | JustForKicks | Axial SCX-10 | 6 | 02-16-2010 05:52 PM |
ESC issue overheating | Flatty | Electronics | 14 | 07-11-2008 10:15 PM |
waterproof an esc without overheating it? | slobin3d | Electronics | 11 | 06-16-2006 09:38 AM |
