08-26-2013, 03:40 PM | #1 |
Quarry Creeper Join Date: Apr 2010 Location: Earth
| CC BEC Pro ??
Whoohoo finally received my new charger today and a CC BEC Pro. Question 1) Can I safely run the output at 7.5V for 7.4V Tactic TSX65 servos? Next step down is 7.0V... Question 2) Can I run both steering servos off of this unit? Question 3) Will i ever get this project done? Thank you, Jason Lasswell Last edited by Vengeance; 08-26-2013 at 04:01 PM. |
08-26-2013, 03:59 PM | #2 |
| Re: CC BEC Pro ??
Probably. Probably, depends maybe, what servos? Probably not. |
08-26-2013, 04:02 PM | #3 |
| Re: CC BEC Pro ??
tactic tsx65 servos
08-26-2013, 04:13 PM | #4 |
| Re: CC BEC Pro ??
Probably. It's basically two 10 amp BECs and unless those are seriously amp hungry servos, you should be fine. A 356 ounces of torque servo is typically easy enough for a single 10 amp CC BEC. |
08-26-2013, 05:42 PM | #5 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| Re: CC BEC Pro ??
I've never been happy with the pros..... With that said 20 amps you should be fine with two servos.
08-27-2013, 12:02 AM | #6 |
| Re: CC BEC Pro ?? |
08-27-2013, 12:10 AM | #7 |
Pebble Pounder Join Date: Jul 2010 Location: California
| Re: CC BEC Pro ??
1) yes because they are rated for 7.4 2)yes just have to figure out your wiring 3)Like eepee said probably not. There`s always something new thing you want to add or have to fix. |
08-27-2013, 12:58 AM | #8 |
| Re: CC BEC Pro ??
Did a rough wiring mock-up tonight. Everything is working well. Running the winch and lights off a CC BEC 10a... Thank you for the feedback everyone.. I do appreciate it. Jason |
08-27-2013, 07:49 PM | #9 |
Rock Crawler Join Date: Oct 2012 Location: Casper
| Re: CC BEC Pro ??
#2: HeyOK built me a 2ch "no-brainer" bec out of the 20A CC that I sent him. Works great!
08-28-2013, 08:43 AM | #10 |
| Re: CC BEC Pro ?? |
CC BEC Pro ?? - Similar Threads | ||||
CC BEC or CC BEC Pro? | alexchen86 | Electronics | 4 | 05-09-2013 12:16 AM |
CC BEC/CC BEC Pro | XDR | Axial Wraith | 10 | 09-24-2011 02:06 PM |
CC BEC Pro | Szczerba | Electronics | 5 | 01-18-2011 07:24 PM |
Castle BEC Pro | JeremyH | Electronics | 7 | 08-23-2009 01:10 AM |
