08-29-2013, 06:09 PM | #1 |
Rock Crawler Join Date: Nov 2011 Location: Omaha, Nebraska
| HELP SV2 not working
Ok i have an sv2 4400kv combo i was driving my truck around about 2 hours ago until the lipo cutoff stopped the fun went and recharged the battery and when it was finished i went threw it back in and turned everything on as normal but nothing i have steering but no throttle no motor chiming nothing from the esc except for solid red and a faint solid green leds were on. please help. whats wrong? just tried to hook it up to castle link and it wouldnt connect to the program. ?!?! so confused and frustrated right now... Kenneth Last edited by jeepscx10; 08-29-2013 at 06:41 PM. |
08-29-2013, 06:45 PM | #2 |
| Re: HELP SV2 not working
Based on this (bottom of the page) .... Castle Creations | FAQ: 1/10th Scale Products Check the TX throttle trim, if it's still "0" (including subtrims), try recalibrating the ESC to the RX. |
08-29-2013, 06:53 PM | #3 |
Quarry Creeper Join Date: Oct 2004 Location: Cow crap flats
Ive had this same issue. burnt out bec. plug your speedo into the castle link and a battery at the same time and it should see it then. 2 options here send it back to castle so the can send you a replacement for like $40 or buy a ccbec for twenty.
08-29-2013, 07:00 PM | #4 |
Everything is set to 0 tried recalibrating but still the same. Did I fry something?
08-29-2013, 07:09 PM | #5 |
I had a spare ccbec hooked it up still nothing and now I don't have steering either I think I will just send it in and get a new one.
08-29-2013, 09:44 PM | #6 | |
| Re: HELP SV2 not working Quote:
As to the external BEC, did you: Check it's output voltage to make sure it's working? I assume it was plugged into the RX, if so, did you remove the red wire from the ESC to RX?? If the RX has power, it should still have steering. | |
HELP SV2 not working - Similar Threads | ||||
br xl or sv2? | Stan3535 | Axial Wraith | 3 | 01-04-2012 04:52 PM |
Sv2 bs! | Jeepkid | Electronics | 1 | 02-17-2011 09:47 PM |
Sv2 | mudn_1 | Electronics | 13 | 02-16-2011 03:59 PM |
Im Working On A Working Wrecker Any Ideas? | LEDDPIPE | General Scale Talk | 7 | 12-13-2006 11:53 PM |
