09-02-2013, 08:33 PM | #1 |
Pebble Pounder Join Date: Mar 2013 Location: Honolulu
| HH Trail Master Sport getting hot
I have a new Wraith build that I'm running a Holmes Trail Master Sport/ BR-XL Combo on 3S Lipo. It was geared 11/56 but after 5 min of driveway testing the motor was way to hot to touch. I just geared down to 10/56 and after the same 3-5 min of driveway testing the motor is still to hot to touch. Should I try 9/56 (lowest I can fit) gearing or am I asking to much of this $12 motor? The reason I like the cheap motor is because I plan to use this rig in water and mud. I'd like to keep the 27 turn instead of a 35 for the speed. I'm running Meyhem wheels non weighted and my rig is pretty much stock weight. Thoughts? Would a 27T Torque Master be better suited and heat up less? Last edited by cox308; 09-02-2013 at 08:35 PM. |
09-02-2013, 08:35 PM | #2 | |
| Re: HH Trail Master Sport getting hot Quote:
09-02-2013, 09:04 PM | #3 |
Make sure none of the drive train is binding. Disconnect the drive lines and make sure the axles and tranny spin freely. I ran a 62/10 with my HH 27t torque master and it never over heated. You can fit a bigger spur than a 56t, just won't be able to run the cover.
09-02-2013, 09:14 PM | #4 |
Rock Crawler Join Date: May 2012 Location: Minneapolis
I have the same motor running 3S in an scx10 with 87/18 Gearing which is actually higher than what you have. It gets pretty warm but not too hot to touch. I agree with crawler nut, you must have something else making the motor work too hard. A decent test would be to run it with a 2S lipo first and see if it does the same. If so, you know you have binding. Did you put any kind of lift kit in it? That could cause driveshaft binding. Also, did you happen to rebuild either the transmission or diffs and fill with grease? If you overfill, you will will have too much load for the motor from the transmission. Dna |
09-02-2013, 09:22 PM | #5 |
You may just be driving it hard, the TrailMaster sport isn't a high efficiency motor and the Wraith is heavy. I would drive it till it stops, use the water too keep it cool!
09-02-2013, 09:55 PM | #6 |
| Re: HH Trail Master Sport getting hot |
09-02-2013, 10:01 PM | #7 |
My 56T rubs a tiny bit. Not sure I could sand enough away to fit a 60. Might give it a try though.
09-02-2013, 10:02 PM | #8 | |
Rock Stacker Join Date: Sep 2012 Location: San Diego
09-02-2013, 10:04 PM | #9 |
| Re: HH Trail Master Sport getting hot The 56t traxxas spur I'm running is damn near touching the MIP driveshaft. Thanks for the advise guys I will check for binding in the drivetrain. I know it's a cheap motor but I want to kill it beacause of an improper set up. |
09-03-2013, 12:26 PM | #10 |
Quarry Creeper Join Date: Mar 2010 Location: Yay Area
I have a BR-XL w/ the TrailMaster Sport on my Wraith. I'm running the 32p w/ 54t spur and 9t pinion. It gets hot as hell! I melted off the HH sticker on the motor on Saturday. Still runs like a champ. I've run the damn motor at least 3 times in the last week burning through three 3s lipo packs each time. No prob. Do like JohnRobHolmes says and burn through the damn thing! Water cooled motors FTW!
09-03-2013, 07:52 PM | #11 |
Rock Crawler Join Date: Aug 2011 Location: Perth west oz
09-03-2013, 10:38 PM | #12 |
I checked out my drivetrain and the axles spin completely free. My trans feels like it has a little bit of resistance. It's running RR steel idler and lower gear. I opened up the trans to check it out and found nothing out of the ordinary. After reassembling the trans it feels the same. I made sure not to over tighten the case scews. Also re checked the pinion/spur gap and it is not binding at all. Oh well! Guess i'll just run it hard and keep a spare on hand. I did just put some weight in my wheels so I'm not expecting it to last to long. |
09-05-2013, 04:36 AM | #13 |
Rock Crawler Join Date: Jul 2013 Location: Kansas City
I too had heat issues until I installed a BEC and geared properly at 84/18,48P plus I changed my driving style from constantly bashing and running hot laps. Now I just cruise around at my little rock garden and my temps seem very cool now. I started out driving my wraith like my savage nitro and I was frying stock axial motors 3 in fact. but good luck man.
09-05-2013, 11:46 AM | #14 | |
09-05-2013, 05:51 PM | #15 | |
09-07-2013, 02:59 PM | #16 |
09-08-2013, 06:23 PM | #17 |
Took my rig out for the first time. Seemed to be ok on the trail but when doing some slow steep crawling the motor started smelling like a burnt turd. Definetly going to put the 9t pinion in next time I open it up and maybe try a larger spur also.
09-10-2013, 09:31 AM | #18 |
Quarry Creeper Join Date: Apr 2009 Location: Lynnwood
i ran 80/20 on my trailmaster sport lol burnt through it pretty quickly, but had fun doing it!
09-13-2013, 09:52 PM | #19 |
I am happy to report that after swapping to a 9t pinion I did a long and hard crawl up Makapu'u trail. This is a local hike about 1/2 long. Nearly the whole trail is pretty hard crawling. The motor didn't seem to get nearly as hot and I got no funny smells. So IMO the Wraith is happy with the HH Trail Master SPORT on 3s lipos with a 1/5.6 rear ratio for trail running and a 1/6.2+ ratio for slow crawling. In a scx10 or 1.9 rig I.d guess that you could gear a little bit higher. Probably 1/5 for trail and 1/5.6 for crawling. Last edited by cox308; 09-13-2013 at 09:55 PM. |
HH Trail Master Sport getting hot - Similar Threads | ||||
HH Trail Master Sport--capacitor question X2 | KC5H | Redcat Crawlers | 4 | 07-14-2013 08:27 PM |
can i use a Trail Master axels? | mr_svensson | Newbie General | 2 | 01-26-2006 07:21 PM |
Tamiya Trail Master | DirkDigler | General Crawlers | 4 | 11-11-2004 10:19 PM |
tamiya trail master | iwantoffroad | General Crawlers | 20 | 10-19-2004 06:18 PM |
