10-10-2006, 12:28 PM | #1 |
Rock Crawler Join Date: May 2006 Location: United Kingdom,Scarborough
| 'y' harness problems
hi my name is jame i have a txt1 my problem is: i just put a y harness on my truck (again) and wired it all up turned my truck on and my receiver. when i steer my truck left the front wheels are suppose to turn left and the back wheels turn right but the don't they both turn left. and same when i steer right. i am running a LRP PRO REVERSE DIGITAL SPEED CONTROLLER 2 FUTABA S3305 HEAVY DUTY SERVO'S FUTABA MEGA TECH 3PM 10 MODEL MEMORY TRANSMITTER Thank you for any information u may be able to provide james |
10-10-2006, 12:35 PM | #2 |
I wanna be Dave Join Date: Mar 2006 Location: One Legend.
Because you are using the same type of servos you need a reversing y harness. You can also flip the servo over on one axle.
10-10-2006, 01:45 PM | #3 |
RCC Addict Join Date: May 2006 Location: In England, looking for the threadlock...
^^ Spot on. This happened to me, so I went to the LHS and asked for a reversing y-harness. The price tag said "£10.49" so I thanked him, and got some more m3 screws. I sorted it by attaching the steering link on the rear servo to the top of the servo horn instead of the bottom. Good luck. Cheers 8-) |
10-10-2006, 04:54 PM | #4 |
RCC Addict Join Date: Mar 2006 Location: Xxx
So there is a y harness and a reversing y harness?
10-10-2006, 04:57 PM | #5 | |
Like we said... Flip one of the servos over or move your servo horn 180 degrees. | |
10-11-2006, 03:26 AM | #6 |
| Grrrrrrrrrr!! Please Help
thanx all for ur help i got the servo's mounted last night now when i drove the truck it stoped and go like its jumping forward and when i go to climb a hill it stops then go's and so on.And it stalls when my servo's are not at nuetral but when i lift the truck up it go's fine! thank you for ur reply so far about my problems james (aged 12) Last edited by Moondust1950; 10-11-2006 at 04:46 AM. |
10-11-2006, 06:29 AM | #7 |
Quarry Creeper Join Date: Feb 2006 Location: Shillington
Sounds like the BEC on your ESC wont handle 4WS. You will need to run a receiver pack or get a better ESC... Good luck. Edit... you can buy a servo reversing Y harness with trim adjustment. I have them in my trucks. They are great. |
10-11-2006, 06:51 AM | #8 |
Mr Maxx has nailed that, I think. Your BEC rating is only 1 amp and can't handle the 2 servos amp draw. |
10-11-2006, 07:02 AM | #9 |
| thanx wow thanx just done that now. big difference in performance
10-11-2006, 10:06 AM | #10 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
If you're looking for a nice reversing Y, check this one out from Expert Electronics: http://www.horizonhobby.com/Products...ProdID=EXRA325 The pot allows you to adjust steering trim on one axle. Makes setup a snap. |
10-11-2006, 10:25 AM | #11 |
thanx may:grin: order one soon
10-11-2006, 02:06 PM | #12 |
OK I have a shafty 14r, with dual Airtronics 94361's . With a super rooster . Now I have no radio in that rig yet cause I am not sure what one to use. So what Radio set up would you recomend for me . :-( Cause I think that type of Y harness that JIA posted is what I need. I have a clod based crawler and the problem I have on that is I have basic 4ws . On that rig I use a DX-3 . With a standard y harness. |
10-12-2006, 08:49 AM | #13 |
^^ Whoa, why didn't you just do a screenshot? Cheers 8-) |
10-12-2006, 01:19 PM | #14 |
hi i couple of post up some one said i didn't have enough B.E.C rating but i just looked at my esc box and there is a B.E.C rating of 5 so it can't be the amps.....or can it? please help i am only 12 i will be greatfull for any information provided thanx james |
10-12-2006, 01:24 PM | #15 |
o yeah forgot my B.E.C ouput voltage is : B.E.C OUTPUT VOLTAGE 5.0 VOLTS B.E.C CURRNET 30 SEC 1.6 AMPS B.E.C CURRENT 5 MIN 0.6 AMPS RATED CURRENT 270 AMPS MAX CURRENT (30 SEC) 100 AMPS CANT. CURRENT (5 MIN.) 55 AMPS REC.MOTORLIMIT NO MOTORLIMIT Last edited by Moondust1950; 10-12-2006 at 01:28 PM. |
10-12-2006, 01:28 PM | #16 | |
10-12-2006, 01:28 PM | #17 | |
10-12-2006, 01:30 PM | #18 |
Wot Would Be A Better Esc?
10-12-2006, 01:33 PM | #19 |
The most popular are: Novak Super Rooster - but it is discontinued Tekin Rebel II Moped There is an ESC sticky at the top of this forum. You can also run a receiver pack! |
10-12-2006, 03:14 PM | #20 | |
