Thread: "Axle Snapper" from B&B Motors
Old 10-10-2006, 12:49 PM   #1
Thumbs up "Axle Snapper" from B&B Motors
I bought a couple of these off eBay and put them in my clod based crawler. They work really good. Loooong run times too. I used the stock 13t pinion and 6 cells. They have plenty of torque to crawl anything I've found. They seemed to be a tad slower than an Integy 55t lathe but since I'm crawling and not racing, the speed issue isn't a big deal. The power, runtime and cost more than makes up for it.
Squirrel is offline   Reply With Quote
Old 10-10-2006, 01:08 PM   #2
Cool.
You can buy those Johnson long can motors for about $5 without the fancy inkjet label.
Whats the deal with a join Date of Dec. 2005 and this is your first post?
I'd call spam alert, but thats a long time to wait to start pimping product.
Unholy is offline   Reply With Quote
Old 10-10-2006, 01:31 PM   #3
Wot, no link?
Seriously though, Integy seems to hold the market for crawler motors (apart from brushless) and I'd like to find an alternative.
Cheers 8-)
4link4eva is offline   Reply With Quote
Old 10-10-2006, 02:23 PM   #4
Originally Posted by 4link4eva
Wot, no link?
Cheers 8-)
I'd suggest the Axiom lathe motor. They have a much smoother throttle response than the Integy and are only a few dollars more. We have them in stock if you're interested. Everyone that I know of that has tried them likes them better than the Integy.
Rockpiledriver is offline   Reply With Quote
Old 10-10-2006, 03:03 PM   #5
I just replaced all my integy with axiom, they are a lot smother and if you like to have throttle control they are the ticket
hotwheels000 is offline   Reply With Quote
Old 10-10-2006, 04:19 PM   #6
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
I have the same type motors that are "axle Snappers", but without the cool labeling. I do like the stickers that B&B slapped on though, pretty nifty.
Shameless plug...
http://www.rccrawler.com/forum/showthread.php?t=41348
JohnRobHolmes is offline   Reply With Quote
Old 10-10-2006, 04:49 PM   #7
Originally Posted by dezfan
You should list them in the vendors sections Johnrob.
Good economy motor.
Where do you think that shamless plug link goes to Dez?!?? :-P
Old 10-10-2006, 04:54 PM   #8
I guess I just haven't ever had anything that intresting to comment on. Thats why I haven't ever posted a thread till now.
Originally Posted by Unholy
Cool.
Old 10-10-2006, 05:00 PM   #9
Im the same way on most subjects. If I dont have anything to say I just pass through. I browsed this forum quite a few months before even joining up.
Old 10-10-2006, 05:03 PM   #10
Says the guy with over 2500 posts!
I browsed the forum for quite a long time before i joined too... but almost a year after joining for his first post ever?!?!?
I'm not flaming at all... I just thought it was weird!
Old 10-10-2006, 05:06 PM   #11
And over 1600 pms in the same time span. I like discussing electrics and the application of individial products in the power system.
Old 10-10-2006, 05:37 PM   #12
Where can I get the Axiom lathe motors at? Who sells them?
Old 10-10-2006, 06:10 PM   #13
Ok im running 2 55 turn b&b motors and im not that impressed running on 6 cells they stall out pretty bad in the rear.And im running 2 esc's and a 4 channel futaba.Any body got any suggestions?
EMUTT is offline   Reply With Quote
Old 10-10-2006, 06:13 PM   #14
Up the cells. I believe the things are really designed for a minimum of 12 volts no matter what they claim.
Old 10-10-2006, 06:42 PM   #15
That sucks i dont think i can run that many on the esc's i have:-( Any way to get the voltage to the motors without going through the esc?Like after the esc somehow?
Old 10-10-2006, 06:47 PM   #16
dezfan's Avatar
Even adding 1 cell w/ help! I use 7 cells when using my MOPED ESC and it is much better than 6 cells.
dezfan is offline   Reply With Quote
Old 10-10-2006, 06:51 PM   #17
yeah, I went from 6 to 7 and it makes a world of differance, I'm thinking about 8 now though.
Kamikaze is offline   Reply With Quote
Old 10-10-2006, 07:11 PM   #18
I will try the 7 cell may look into other esc's how many cells can the mopeds handle?
Old 10-10-2006, 08:14 PM   #19
The Motors are actually 24 volt jobbers. They work nicely on 12 volts in a crawler.
Old 10-11-2006, 08:51 AM   #20
12 volts? No problem, it just means I'll have to scrape the melted mess of the MOPED from my chassis...
Cheers 8-)
