09-09-2013, 07:20 AM | #1 |
Rock Crawler Join Date: Apr 2012 Location: Bella Vista
| motor timing?
How many degrees is each notch on a brushed motor can?
09-09-2013, 07:38 AM | #2 |
Rock Crawler Join Date: Aug 2011 Location: Perth west oz
| Re: motor timing?
about 6 deg
09-09-2013, 08:17 AM | #3 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
| Re: motor timing?
Each notch in most endbells is 12 degrees. Later EddieO |
09-09-2013, 11:30 AM | #4 |
| Re: motor timing?
Thank you both.
09-11-2013, 03:33 PM | #5 |
Rock Crawler Join Date: Jul 2013 Location: Kansas City
| Re: motor timing?
What is the benefit of advancing the timing, like a real car, gives it a little more punch and run more efficiently?
09-20-2013, 06:18 AM | #6 |
| Re: motor timing?
Pro: You get more top speed and power out. Con: You get less torque and efficiency. Conclusion: Not useful for crawling (unless it's dynamic as done by the MMP). |
09-20-2013, 06:02 PM | #7 |
Rock Crawler Join Date: May 2012 Location: Upland
| Re: motor timing?
You should not go by the notches without knowing what each notch is. Go by temperatures and how fast you want it. Get a faster motor before you give too much timing
09-20-2013, 10:47 PM | #8 | |
| Re: motor timing? Quote:
+1. Keep in mind on a brushed motor, if you add a lot of timing for forward, you are running really retarded in reverse. For crawling, a little timing can be OK, but don't go too nuts. Other types of RC almost never use reverse, so lots of timing is not as much of an issue. | |
motor timing? - Similar Threads | ||||
motor timing | cowboy_crawler | Electronics | 6 | 12-10-2012 07:43 AM |
Motor Timing? | armycrawler101st | Electronics | 4 | 01-26-2011 09:11 PM |
Motor timing.... | brokennib | Electronics | 5 | 01-19-2011 04:58 PM |
Timing a Motor | Harvo | Newbie General | 7 | 12-23-2008 07:00 PM |
Motor Timing | Rooney7783 | Electronics | 9 | 03-08-2006 03:07 PM |
