09-17-2013, 09:57 AM | #1 |
Newbie Join Date: Sep 2008 Location: Littleton
| ? on dx4s
I just got the dx4s and am having issues trying to got esc to bind with the transmitter? I have installed the new update for the moa. I am run castle sidewinders mirco and Castle bec . Last edited by goalsrock; 09-17-2013 at 11:19 AM. |
09-17-2013, 09:02 PM | #2 |
| Re: ? on dx4s
Bind = TX & RX Calibrate = ESC to RX So....which is your issue? I will assume it's the binding since you did an update on the TX. |
09-17-2013, 09:30 PM | #3 |
| Re: ? on dx4s The bind went fine, but I can not get rather of the two esc to bind. Right now the bec is the bind slot . One esc is in aux 1 the other is in aux 2. The power wire is out of both of them. But all I get is flashing yellow light from both of the esc. Do I need to do change something in the transmitter? I am at a loss as to what to do. Thank for the reply.
09-17-2013, 10:11 PM | #4 |
| Re: ? on dx4s
1 ESC in the throttle channel (channel 2) 1 ESC in channel 3(?, depends on the radio) TX throttle channel to 100% EPS, "0" trim. Turn on TX, hold full throttle, turn on rig, wait for chime, full reverse, wait for chime, go to neutral, wait for chime. You're done. Note, if no motor connected, no chime would be heard. Castle info..... read near bottom.... Castle Creations | FAQ: 1/10th Scale Products |
09-17-2013, 10:13 PM | #5 |
Pebble Pounder Join Date: Mar 2009 Location: nc
| Re: ? on dx4s
I know with my radio which is different I had to do the esc's separate, just unplug one from the rx and do the other
? on dx4s - Similar Threads | ||||
Spektrum DX4S Thread | MitchellY | General Crawlers | 69 | 04-05-2017 11:53 PM |
DX4S Programming | kam2040 | Electronics | 18 | 06-28-2016 12:02 AM |
dx4s tips | donzx12 | Electronics | 1 | 01-24-2013 01:09 PM |
DX4s | roksloski | Electronics | 3 | 12-26-2012 08:20 PM |
