09-18-2013, 01:42 PM | #1 |
Quarry Creeper Join Date: Mar 2008 Location: Redlands
| Wiring a ccBEC
Ok, just finishing up my Wraith, got a question on the ccBEC wiring Currently, I have a spektrum 4ch receiver THR - ESC STR - Servo AUX1 - BEC AUX2 - BIND/BATT - If I decided to run lets say a dig, or lights, or both, am I able to plug the BEC into the BIND slot? Or just stick with how I have it now. I know I can add the dig servo to AUX2, and lights inline with AUX1 (with how the BEC is setup now) |
09-18-2013, 01:51 PM | #2 |
Rock Stacker Join Date: May 2010 Location: Tacoma
| Re: Wiring a ccBEC
My futaba 4ch is plugged into the batt leaving the other 2 channels free so it should be fine on yours.
09-18-2013, 02:42 PM | #3 | |
Rock Crawler Join Date: Nov 2011 Location: clarksville,ar
| Re: Wiring a ccBEC Quote:
09-18-2013, 02:42 PM | #4 |
RCC Addict Join Date: Mar 2011 Location: Katy / west houston
| Re: Wiring a ccBEC
do this... . |
09-18-2013, 03:54 PM | #5 |
| Re: Wiring a ccBEC |
09-18-2013, 07:00 PM | #6 |
| Re: Wiring a ccBEC
The BEC will only be feeding the servo instead of rx, servo, lights and dig servo if you ever want to do them as you were saying. This way the external BEC will only power the servo and the internal BEC will be doing the rest.
09-18-2013, 07:09 PM | #7 |
Makes sense. I would assume I can use a y harness for the BEC and servo connection? Sent from my HTC One using Tapatalk 4 |
09-18-2013, 07:12 PM | #8 | |
Rock Crawler Join Date: Oct 2012 Location: Trail B.C.
I usually use a Y harness and remove the red wire from the harness on the end it plugs into the receiver. This way you need not cut any wires or make anything permanent. Just plug in the BEC and servo and plug that into the channel 1 or steering. | |
09-18-2013, 07:50 PM | #9 |
Rock Crawler Join Date: Aug 2011 Location: Perth west oz
| Re: Wiring a ccBEC
It is a good practice to run a common ground (black wire) between the Rx and Servo. I know a lot of people don't do it and have no problem, but this just eliminate a possible source of glitching. You can just use a Y harness and cut the Red wire to the Rx and the signal wire (wire or orange depends on brand) from the BEC. |
09-18-2013, 07:53 PM | #10 |
09-26-2013, 10:13 AM | #11 |
Pebble Pounder Join Date: Nov 2012 Location: united kingdom
| Re: Wiring a ccBEC
also does anyone have a picture on what it looks like with the y harness...sorry but this stuff is very confusing for me although i'm sure it's quite simple!
09-26-2013, 10:14 AM | #12 |
| Re: Wiring a ccBEC
does anyone have a picture on what it looks like with the y harness...sorry but this stuff is very confusing for me although i'm sure it's quite simple! and is the a suitable y harness? Expert Electronics Y-Harness 6"/Reverser Standard |
09-26-2013, 09:05 PM | #13 | |
| Re: Wiring a ccBEC Quote: A simple Y harness for hooking up 2 servos is all thats required. They can be had on the bay for 5 bucks for 3 shipped. Last edited by jaloos; 09-26-2013 at 09:09 PM. | |
12-10-2014, 03:21 AM | #14 |
Newbie Join Date: Jan 2014 Location: wingate nc
| Re: Wiring a ccBEC
You have a pm about the roc412 you selling send me your paypal I'll take it
Wiring a ccBEC - Similar Threads | ||||
esc ccbec wiring? | s2000ax10 | Electronics | 2 | 03-13-2012 06:20 PM |
CCBEC or CCBEC Pro | Lambo3244 | Electronics | 12 | 07-14-2011 01:24 AM |
CCBec? | nitropain | Electronics | 1 | 11-13-2010 05:13 PM |
CCbec | Tortuga275 | Electronics | 3 | 01-16-2010 08:54 PM |
CCBEC wiring issues | dezertdog | Electronics | 2 | 10-09-2007 10:02 PM |
