09-20-2013, 12:34 PM | #1 |
Rock Crawler Join Date: Jun 2013 Location: Cincinnati
| Thin 3s?
Has anyone run across some thinner 3s packs? I want to be able to run 1 on each rock slider (after I build a tray) and still have it low enough to put some sort of interior in there. I keep finding packs that are shorter but still thick.
09-20-2013, 12:43 PM | #2 |
RCC Addict Join Date: Jul 2008 Location: Fox Valley WI
| Re: Thin 3s?
From what I've seen from browsing through lipo ads, anything over about 2,200 mah tend to be thicker. I'm sure there are packs out there that would work, but companies don't always provide the dimensions of their products.
09-20-2013, 12:48 PM | #3 |
Rock Stacker Join Date: May 2013 Location: Appalachia
| Re: Thin 3s?
You could probably use a Zippy Flightmax 2200mah 3S.
09-20-2013, 01:03 PM | #4 |
Quarry Creeper Join Date: Oct 2004 Location: Cow crap flats
| Re: Thin 3s?
sky lipo 3000 mah 3s - same size as and hardcase 2s pack. in stock at hobbypartz. Sky Lipo 3000mAh 11.1V 30C |
09-20-2013, 01:06 PM | #5 |
| Re: Thin 3s?
Thanks guys, I was actually going to try for thinner than 2s hardpack - I could very well be SOL here.
09-20-2013, 01:19 PM | #6 |
In the band for now. Join Date: Sep 2012 Location: roselle
| Re: Thin 3s?
try valuehooby.com they list all the sizes of there lipos
09-20-2013, 02:47 PM | #7 |
Rock Crawler Join Date: May 2012 Location: Australia
| Re: Thin 3s?
1000mah 3s are about 15mm thick. Basically you will have to reduce the amount of mah to make it thinner. |
09-20-2013, 02:59 PM | #8 |
| Re: Thin 3s?
Hobbyking lists the dimensions of all of their lipos.
09-20-2013, 03:58 PM | #9 |
Quarry Creeper Join Date: Sep 2013 Location: post falls
| Re: Thin 3s?
Wouldn't running a 3s with less mah give you less power then a higher mah 2s?
09-20-2013, 04:04 PM | #10 |
| Re: Thin 3s?
No. 3S is going to give you more power than 2S. You'll have a lower capacity(run time). I run my 2S 5000mah when I have a free afternoon to bash around. I use my 3S 2200 when I don't have so much time and I want a bit more power. Last edited by OhioGuy82; 09-20-2013 at 04:07 PM. |
09-20-2013, 06:09 PM | #11 | |
| Re: Thin 3s? Quote:
Any time you buy packs you should make sure that they can produce the amperage that your system is capable of drawing. | |
09-20-2013, 06:15 PM | #12 |
| Re: Thin 3s?
mine does well terrorizing the neighborhood dogs in a 4x4 sct with a 3800k castle 4 pole and an sv2.
09-20-2013, 10:43 PM | #13 | |
| Re: Thin 3s? Quote:
Low mah & low "C" will suck in most rigs when you need some punch. | |
09-21-2013, 08:21 PM | #14 |
| Re: Thin 3s?
Ok, so basically I can't get more power with higher mah, just longer run times, damn that sucks since I don't have.room for anything bigger then 2s.
09-21-2013, 08:24 PM | #15 |
| Re: Thin 3s? |
09-22-2013, 09:36 AM | #16 |
| Re: Thin 3s? |
09-22-2013, 11:29 AM | #17 |
| Re: Thin 3s?
Available space is 103mm long, 40mm wide, 32mm tall
09-22-2013, 06:11 PM | #18 |
| Re: Thin 3s? This 3s 2250mah 65c-130c is 104mm: Turnigy nano-tech 2250mah 3S 65~130C Lipo Pack This 3s 1800mah 65c-130c is 103mm: Turnigy nano-tech 1800mah 3S 65~130C Lipo Pack |
09-22-2013, 06:22 PM | #19 | |
| Re: Thin 3s? Quote:
Thin 3s? - Similar Threads | ||||
Where to get thin aluminum? | Snowwheeler | General Scale Talk | 5 | 04-09-2012 12:06 AM |
Caution Thin ICE | hitman46mod | Michigan | 29 | 12-10-2009 05:54 AM |
Thin delrin? | 47willysbuggy | Tools, and Procedures | 8 | 06-10-2009 08:32 PM |
Thin lexan? | Cslax06 | Chit Chat | 5 | 08-23-2007 02:24 PM |
