Thread: what size pinion for a 35t motor
Old 09-23-2013, 01:34 PM   #1
Default what size pinion for a 35t motor
was wondering what would be a good tooth size pinion for a tamiya cr tuned 35t motor in a scx10 running the ae-2 esc using a 5300mah 2s lipo`s.
it would be mainly for fun running with some comp style running aswell.
forgot to say iam running a 85t spur gear
boohoo is offline   Reply With Quote
Old 09-23-2013, 01:36 PM   #2
Default Re: what size pinion for a 35t motor
Read up on some gearing threads. This has been discussed in every forum hundreds of times.
crawler nut is offline   Reply With Quote
Old 09-23-2013, 01:40 PM   #3
every thread ive seen they are using the 87t spur but iam not iam using a 85t spur so my gearing is differenet thats why aim asking
Old 09-23-2013, 01:57 PM   #4
2 teeth difference on the spur does not make a difference.....pretend you have an 87 tooth spur and go from there.
War Pig is offline   Reply With Quote
Old 09-23-2013, 02:19 PM   #5
What ratio is being suggested? Simply doing the math will show you how little difference there is between an 85t and and 87t. 87/14=6.2:1 85/14=6.1:1 Variations in the build quality of motors, lipos, and the variations of scx builds would make a much larger difference than the .1:1 ratio change will.
Calderwood is offline   Reply With Quote
Old 09-23-2013, 03:35 PM   #6
PapaGriz Yo
Grizzly4x4's Avatar
Your tire/wheel size would make a bigger difference than 2 teeth on the spur.
On a rig with 1.9's and 4.75" tires I like an 84/20 gear setup.
On a 2.2 with 5"+ tires I like 84/16.
Grizzly4x4 is offline   Reply With Quote
Old 09-23-2013, 07:11 PM   #7
Standard RTR come as 87/20 In think, so if you have not change the tire, 84/19 or 84/18 would the way to start, just get a bunch of 20, 18, 16, 14 and try it.
Colgout is offline   Reply With Quote
what size pinion for a 35t motor - Similar Threads
tekin 35t crawler motor what size? deleeum23 Newbie General 11 03-18-2012 04:32 PM
Pinion for 35t Motor BennyTRD Newbie General 3 04-05-2011 04:40 PM
pinion size and motor temps RickM Losi Mini-Rock Crawler 0 04-02-2011 08:56 PM
pinion size for a 35t in a LNC FruitaCrawler Team Losi Comp Crawler 4 03-16-2011 09:50 AM
Relationship between pinion size and motor T°?? raolguio Newbie General 3 11-17-2010 07:02 PM
