09-26-2013, 12:07 AM | #1 |
Pebble Pounder Join Date: Sep 2005 Location: Citrus Heights, CA
| can a 5955tg be turned into a winch?
Well yesterday I was crawling my scaler and after about 20 mins my stearing went out. Its a hitec 5955tg. When I checked it it moved freely so I touched the servo and it was so hot that it burned my finger on the heat sinc. So after it cooled down I opened it up and the 2 chips on the board are melted a little and it smells burnt. My question is can I turn this servo into a winch servo by getting a new board? Thanks Jeff
09-26-2013, 12:58 AM | #2 |
Rock Crawler Join Date: Jun 2011 Location: Vancouver
| Re: can a 5955tg be turned into a winch?
yes, u can make it as servo winch as long as the motor is in working condition, and also check those gears. |
09-26-2013, 07:41 AM | #4 |
This might be of some help to you: Another servo winch building tutorial |
09-26-2013, 08:11 AM | #5 |
Hey thanks you guys. I'm for sure making this thing into a winch for my gride.
09-27-2013, 10:19 AM | #6 |
SuperShafty.com Join Date: Jan 2008 Location: Visalia CA
any servo can make a winch. just gotta get the HEYOK controller and resolder to the motor poles.
09-27-2013, 11:10 AM | #7 |
Moderator Join Date: Jan 2004 Location: chicago
be carefull when removing the board from the motor. prying up while trying to unsolder the board from the motor can sometimes break off the motor tabs. some solder wick or a solder bulb will help suck the solder out and keep the motor tabs in place. theres a thread somewhere on here about it. |
09-27-2013, 11:50 AM | #8 |
This pic shows two places where you need to remove the solder. There is a third place that I forgot to mark, but the pic shows the solder removed. It is just above and to the right of the second large IC starting from the left. |
09-27-2013, 06:58 PM | #9 |
Ok cool thanks. I will be ordering a controller as soon as I get some extra cash
09-27-2013, 08:02 PM | #10 |
Also very important, don't forget to remove the pin from the main gear |
can a 5955tg be turned into a winch? - Similar Threads | ||||
Hitec 5955tg | Hacksaw707 | Electronics | 9 | 10-23-2012 09:41 AM |
how is the hs-5955TG | theclimber | Electronics | 11 | 10-07-2011 09:34 PM |
HS-5955TG issues? | Offroader5 | Electronics | 4 | 01-20-2007 11:29 PM |
Smoked HS-5955TG | DISTURBIN' tha PEACE | Electronics | 10 | 10-07-2005 04:02 AM |
