09-27-2013, 02:45 PM | #1 |
Newbie Join Date: Jan 2013 Location: West Columbia, SC
| Scx10 motor very hot
I dont know what is going on with my Huncho. I have the stock ESC, after running it for a 10-15min the motor gets very very hot (27T) and it will lose power. any ideas about what is going on? The transmission moves freely, no binding at all from motor to wheels |
02-08-2014, 03:01 PM | #2 |
Rock Stacker Join Date: Jan 2012 Location: Winston-Salem
| Re: Scx10 motor very hot
No answers to this question? I'm having the same problem
02-08-2014, 03:10 PM | #3 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
Is your gearing stock on it?..The stock 20T motor pinion does tend to make the motor a little warm...try gearing down..try a 16T motor pinion. Do you lube the bushings on the motor?..After every few runs its recommended to lube the bushing..No lube equals friction equals heat. Last edited by 6sharky9; 02-08-2014 at 03:15 PM. |
02-08-2014, 03:11 PM | #4 |
Rock Crawler Join Date: Nov 2011 Location: clarksville,ar
Never mind, the og post is a little old....
02-08-2014, 03:16 PM | #5 |
| Re: Scx10 motor very hot |
02-08-2014, 03:49 PM | #6 | |
| Re: Scx10 motor very hot Quote:
Is this the correct 16T pinion? http://www.rcplanet.com/Axial_Pinion...p/axi30842.htm I realize that but it has my exact question, why make another thread.. Last edited by RubikonKid; 02-08-2014 at 03:54 PM. | |
02-08-2014, 04:23 PM | #7 |
Rock Crawler Join Date: Oct 2012 Location: Casper
The mesh they are talking about is how tight your motor gear (pinion) is to the trans gear (spur). And it sounds to me like it's probably tight. Loosen the bolts that hold the motor. Put a piece of paper between the gears and hold the pinion snug to the spur while you re-tighten the bolts. Roll the paper out from between the gears. It shouldn't be so tight that the paper gets cut by the gears but shouldn't be so loose that one gear can turn without turning the other.
02-08-2014, 06:03 PM | #8 | |
Look up robinson racing pinion gears. And what hes saying about the gear mesh is right...if its too tight it will cause the motor to strain all the time and cause it to get hot. The gear mesh is where you are connecting the 2 gears..too loose and you strip out the gear..to tight and you get hot and destroy the gear. The gear change will lower your temps under normal condition and give you better low speed control in general...it will take away some speed though..so keep that in mind. Last edited by 6sharky9; 02-08-2014 at 06:07 PM. | |
02-10-2014, 06:24 AM | #9 | |
02-10-2014, 06:27 AM | #10 | |
02-11-2014, 04:59 PM | #11 |
Thanks for the help. I just got done tearing it down and checking the gear mesh. It adjusted it but it ended up being too loose so I re-adjusted. Cleaned out the rear differential and gave a little lube. Played with it around the house for about 15ish minutes and after that it was pretty hot to the touch. I'm not sure where to go from here. Btw, here is a picture I've been meaning to post |
02-11-2014, 05:06 PM | #12 |
Ditch those connections! Wire it straight to each other or get some dean's plugs. Then upgrade ur motor... |
02-11-2014, 05:41 PM | #13 | |
I was looking at the Tekin 35T earlier but I just don't have money to drop on a new one right now. | |
02-14-2014, 09:30 PM | #14 |
Quarry Creeper Join Date: Nov 2007 Location: Orygun
Those bullet connectors have a lot of electrical resistance, hence the deans plug suggestion. I typically hard wire my motors, but have thought about a plug set up too. Your wires are burning because of the heat and resistance going on thru the plugs. Ditch those asap. |
02-15-2014, 07:36 AM | #15 | |
02-15-2014, 10:43 AM | #16 |
I'm not convinced the motor is your issue.
02-17-2014, 10:43 AM | #17 |
Scx10 motor very hot - Similar Threads | ||||
Motor getting hot | jeepscx10 | Electronics | 17 | 10-26-2013 11:29 PM |
How hot does the motor get? | jbsmith05 | Axial AX10 2nd-gen | 4 | 04-15-2013 05:10 PM |
How hot is too hot for the motor? | Mr. Ed | Losi Mini-Rock Crawler | 4 | 06-13-2010 11:09 PM |
motor temp - how hot is too hot? | wicked4x4 | Newbie General | 16 | 03-18-2010 09:49 AM |
Hot Motor | Nish | Electronics | 12 | 05-20-2009 04:55 PM |
