Thread: gt3c battery shot?
Old 09-28-2013, 02:51 PM   #1
Default gt3c battery shot?
left it on the other night. all night. goes to 3.6v and beeps low voltage. u charged it a bunch. dies real fast and beeps.. didnt get the hack kit yet.. is there something i can cut out or un solder and make it stop beeping till i get a new battery thanks
m1009cucv is offline   Reply With Quote
Old 09-28-2013, 03:14 PM   #2
Default Re: gt3c battery shot?
Sounds like it's dead.
Yes, you could rip the TX apart and cut wires to stop the beeping, but why?????
Old 09-29-2013, 07:17 AM   #3
agreed , just get a new batt.
crawlhog is offline   Reply With Quote
Old 09-29-2013, 08:23 AM   #4
true.. ill open it up when i get the hack kit. ill get a new battery. wonder if there is one with more power? ill see if i find one thanks
Old 09-29-2013, 08:28 AM   #5
looks like I need to wait for one from China. Can't find them in stock. Dammit
Old 09-29-2013, 08:40 AM   #6
It's a 1c LiPo, so if you want to hack it, you can use any 1c pack for it.
ik632 is offline   Reply With Quote
Old 09-29-2013, 09:00 AM   #7
the biggest one you can get from flysky is the 1200mah for the it4. i have one in my gt3c and it last longer than i thought it would and its only slightly dearer than the 800mah you get with the controller i think it was only $4-5 dearer
boohoo is offline   Reply With Quote
Old 09-29-2013, 10:01 AM   #8
It has a funky edge connector for power, thus it will take some "modding" to wire in another pack. It's NOT a plug on a harness.
In case you didn't know.
Old 09-29-2013, 06:41 PM   #9
Yeah, that's why I said "hack" it
Old 09-29-2013, 10:46 PM   #10
Got Worms?
With the hack kit you can turn the low voltage alarm down to 3 volts.
There's only two batteries made that'll fit in the gt3c.. the stock 800mah one and the fs-it4 1200mah battery.....gt3c batteries have a lower cost per mah....
Other 1 s lipos will work but will require modifications...and i haven't found a battery worth doing mods over instead of just using flysky batteries.
losikid is offline   Reply With Quote
Old 09-30-2013, 06:17 AM   #11
ok will you have the battery in stock soon? no one seems to have it.
Old 02-09-2014, 05:34 AM   #12
Hi losikid
You mention that with the hack kit it can turn the low voltage alarm down to 3 volts, but I cant set it to 3.0v but I hacked my GT3C and it only gets to down 7.5v doesn't go down from that , has anyone had this problem, now when I turn the radio its always beeping
Can someone give a help here please?
PSH72 is offline   Reply With Quote
gt3c battery shot? - Similar Threads
flysky gt3c 1200mah battery and 10-bc charger boohoo Electronics 3 09-07-2013 02:37 PM
FS GT3C Problem / Need help KC5H Electronics 3 09-03-2013 07:45 AM
gt3c battery life question boohoo Electronics 5 08-06-2013 04:51 PM
GT3C: Need your opinions losikid Electronics 12 03-21-2013 05:47 PM
