Thread: Recommended ESC/Motor Combo?
Old 09-29-2013, 03:20 PM   #1
Default Recommended ESC/Motor Combo?
Ok, so I'm wanting plenty of torque and speed on an SCX10. Wanted to go with the Sidewinder 3 w/ RC4WD 35T motor. Thoughts? Greatly Appreciated
Dmillsaps is offline   Reply With Quote
Old 09-29-2013, 03:44 PM   #2
Default Re: Recommended ESC/Motor Combo?
I would spend a little more money and get a waterproof HH BR-XL with a HH Torque Master Pro 27t.
k7zpj is offline   Reply With Quote
Old 09-29-2013, 06:59 PM   #3
Yeah.. im on a small budget..and i like the 27 but im comfortable with a 35...and i have seen the br-xl.. but like i said. small budget. ill just let some other people post and get some ideas and see my options
Old 09-29-2013, 07:11 PM   #4
hh brxl dont cheap out it will handle what ever you through at it and fully programmable then put what ever motor u want with it get a star and get in the classifieds you can find one at a third of the cost
mark32 is offline   Reply With Quote
Old 09-30-2013, 08:24 AM   #5
There are a few BR-XL appear in the classified, also look at used FXR. For motor, the RC4wd one is not rebuildable. While it seems you are saving a bit but they can be rebuilt so in the long run, they are more expensive. How about HH torquemaster sport. They are about $40 each I think.
Colgout is offline   Reply With Quote
Old 09-30-2013, 06:45 PM   #6
Trailmaster is 27t? Right? NEED 35t. Thx 4 help.
Old 09-30-2013, 07:14 PM   #7
HH has a variety of different turn motors and a variety of prices. No matter what you get from him you can't go wrong. Why don't you shoot him an email including your rig specs. Model, weight, tire size, battery used- cell count and mah and he will set you up with what you need. No offense, but these what motor and esc for my ??? belong in the newb section.
crawler nut is offline   Reply With Quote
Old 09-30-2013, 07:21 PM   #8
I ran that exact same setup this weekend it worked great....not the fastest but not a 55t either....actually the best cheap fast scaler motor ive used is the $15 tamiya silver can 27t 540J.....friend of mine was running it in my steel tuber and it wad haulin a$% but could still crawl pretty good
Sent from my PI39100 using Tapatalk
stevetate12 is offline   Reply With Quote
Old 10-01-2013, 12:04 AM   #9
Originally Posted by Dmillsaps View Post
... I'm wanting plenty of torque and speed on an SCX10. ...
... im on a small budget.
Now there are some impossibilities...
The SCX10 can't handle plenty of torque and speed unless you spend some money upgrading the drive line before letting loose the power required.
But then again... it depends on your definition of "plenty"...
Olle P is offline   Reply With Quote
Old 10-01-2013, 06:27 AM   #10
Im not talking ripping 30+ mph just some wheelspin to get out of stuff.
Old 10-01-2013, 06:35 AM   #11
OK, thanks i might do that.
Old 10-01-2013, 06:49 AM   #12
Then it's by no means "plenty" but rather normal.
A cheap 45T motor and 3S Lipo should then give you more torque and speed than you require...
Old 10-01-2013, 02:13 PM   #13
Question Re: Recommended ESC/Motor Combo?
I wont be using lipo, it'll be a 5000MAH nimh battery :P
And a 45 turn sounds a bit slow? I don't know though...
Old 10-01-2013, 05:39 PM   #14
Personally o found the 35t a little slow....wad running a 2s lipo....i like the 27t better
Old 10-01-2013, 05:57 PM   #15
The 27t a bit TOO fast to look scale.
Old 10-01-2013, 06:19 PM   #16
Maybe.....but im light on the throttle when needed....if that's the case for you the 35t would most likely be perfect..
Old 10-02-2013, 03:29 AM   #17
45T is fairly slow on 8V, like modest walking speed when running flat out.
That's why I suggest a higher voltage to go with it.
The combo will provide more torque at low speed, better top end and higher efficiency compared to running a lower wind motor on lower voltage.
Old 10-02-2013, 06:35 PM   #18
Well my 35T motor should come in tomorrow and my SV3 should come in friday.
Old 10-02-2013, 07:14 PM   #19
I do live the sv3....you are gonna have to program it out of the box it comes set up for brushless....set it for crawler reverse....crawler drag brake....and of course set the motor as brushed reverse...no delay for reverse
Old 10-02-2013, 08:06 PM   #20
I run a 35t on 3s geared 16/87 and it works good for what I like.. not blazing speed, but enough for how I like to drive...and my temps stay nice... I had a wp brxl, but it's needing to be sent in to get looked at. I ran an axial ae-2 this Saturday at our locak g6. Hooked a bec up to it and ran 3s all day like a champ...my son has had an sv3 since castle first released it and it's been great...no issues after castle updated the firmware for it... it'll do what you need it to.
mjc597 is offline   Reply With Quote
Recommended ESC/Motor Combo? - Similar Threads
ESC/motor combo help JTG671 Electronics 1 09-07-2011 12:09 AM
Choice for ESC or ESC motor combo fivepointnine98 Newbie General 10 07-05-2011 03:21 PM
motor esc combo help? sidewaystreak Venom Creeper 21 04-15-2010 08:48 AM
