09-29-2013, 07:12 PM | #1 |
Pebble Pounder Join Date: Dec 2007 Location: Arvada
| Tekin fxr help
I just got a tekin fxr. Everything was really clear and easy for the install. But now I'm having a hard time for getting the truck to reaspond right. Their directions for setting it up are not good. The truck doesn't always have dragbrake and it pauses from reverse to forward. Sometimes it even pauses if you let off the throttle and hit it again. It lights up as if it has the signal but won't move untill you let off and hit it again. Help?
09-29-2013, 07:34 PM | #2 |
RCC Addict Join Date: Mar 2011 Location: Katy / west houston
| Re: Tekin fxr help
You have to turn on instant reverse in the programing, the stock program has a delay.
09-29-2013, 07:54 PM | #3 |
| Re: Tekin fxr help
That's my problem. How do I switch the programs?
09-29-2013, 07:58 PM | #4 |
RCC Addict Join Date: Aug 2009 Location: Earth?
| Re: Tekin fxr help
Read the manual. The best way is to buy a "Hot Wire" to program it.
09-29-2013, 08:13 PM | #5 |
| Re: Tekin fxr help |
09-30-2013, 07:32 AM | #6 |
| Re: Tekin fxr help
Not sure what is going on with it now. Got everything to work. My only issue is that I have full drag brake after moving forward but not reverse. Any ideas of what's going on?
09-30-2013, 04:24 PM | #7 | |
| Re: Tekin fxr help Quote:
If you're in Arvada, CO., stop into the Hobby Shop there (Crawl Space?), they can help out. | |
09-30-2013, 07:09 PM | #8 |
Rock Crawler Join Date: Jan 2013 Location: San Diego
| Re: Tekin fxr help
Like Charlie said, recalibrate the esc to receiver. Then read the manual again, even if you already have. I missed some things the first time. To program the esc, turn everything on, then press mode. Use the table in the manual to determine what the abbreviations mean. Experiment with settings until you get the feel you want. By the way, turning the ESC off then back on saves your settings and puts you back into driving mode.
10-01-2013, 04:32 PM | #9 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
| Re: Tekin fxr help
Can you put up a picture of your wiring? When you drive foward, do the LEDs light up from left to right? |
10-01-2013, 04:47 PM | #10 |
10-03-2013, 08:18 PM | #11 |
Newbie Join Date: Oct 2011 Location: eastern sierra
10-04-2013, 10:28 AM | #12 |
Rock Crawler Join Date: Jan 2011 Location: At home
| Re: Tekin fxr help
If the throttle trim is set forward on the TX, it will eliminate dragbrake ... I found out a similar way, took the rig out and no dragbrake al of a sudden. Day before no problems, after some exploring I found out the throttle trim was turned a few clicks (2-3) forward. Resetting it fixed the problem Check your TX to rule this possibility out ... If you need to set throttle trim to keep it from riding when no throttle is used, you need to recalibrate |
Tekin fxr help - Similar Threads | ||||
Mamba Max , Tekin FXR or Tekin FXR PRO? | TheHeadHunter | Electronics | 21 | 06-21-2012 08:15 AM |
Tekin FXR and FXR-pro ESCs in stock | JohnRobHolmes | Holmes Hobbies | 35 | 09-17-2009 09:40 PM |
