10-01-2013, 07:52 PM | #1 |
Newbie Join Date: Jul 2013 Location: USA
| HH Torquemaster Expert 35t hanging up.
The motor will just kind of stall and you have to give it a nudge to get it going again. Cleaned everything the best I could multiple times. Now this last time after cleaning and reassembling the motor, as I take the motor up the full throttle it just kind of clicks and goes WOT even after letting off the accelerator and stays there until I unplug the battery. I took lots of pictures of the motor apart. Any ideas would be helpful. I'm using a BR-XL waterproof ESC that i'm guessing wasn't so waterproof. See my thread here - Dead BR-XL. Anyhow after it dried out for a couple of days it started working again. I've tested the stock 27t axial motor and it doesn't exhibit these same issues. Last edited by Red04Cobra; 10-01-2013 at 07:58 PM. |
10-01-2013, 09:57 PM | #2 |
Rock Crawler Join Date: Jan 2013 Location: San Diego
| Re: HH Torquemaster Expert 35t hanging up.
It looks like you have some corrosion on your brushes and comm. Get a comm lathe and shave off the top crap (or get a new armature if you don't want to buy a lathe) and new brushes.
10-01-2013, 10:15 PM | #3 |
Rock Crawler Join Date: Feb 2010 Location: in a Fishbowl watching time go by
Brushes look suspect to me, HH will rebuild with new brushes for 10 bucks.
10-01-2013, 10:19 PM | #4 |
Quarry Creeper Join Date: Dec 2012 Location: Seattle
I have had good results with just getting a piece of scotch bright and cleaning it good and getting the crusty off every thing, then spraying off any extra debri and replacing it all. everything looks good from the pics to me.
10-02-2013, 12:51 AM | #5 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
Everything looks fine? Uh no... Motor clearly has been ran in water....and then not cleaned afterwards. Brushes are about 1/3rd their normal length and the comm is hammered. The brushes are probably struggling to make solid contact because of the comm condition, along with the length being so short, the springs are not pressing very hard. Assuming the comm cleans up well from a cut, you will need to replace the brushes and all should be fine....do not use scotch brite to clean the comm. Find a person with a lathe, buy a lathe or send it in to Holmes for a rebuild. In the future, clean the motor out with some motor spray or compressed air after you run in the water. Later EddieO |
10-02-2013, 06:05 AM | #6 | |
| Re: HH Torquemaster Expert 35t hanging up. Quote:
Did lots of reading between this weekend and last night and troubleshot it to the point where I was thinking the same thing as you. So i'm happy to have that reaffirmed. Guess i'll be shopping for a comm lathe and some new brushes! | |
10-02-2013, 06:54 AM | #7 | |
Now, none of this explains the, "Now this last time after cleaning and reassembling the motor, as I take the motor up the full throttle it just kind of clicks and goes WOT even after letting off the accelerator and stays there until I unplug the battery" comment. Sounds like you still have a ESC issue either in the ESC or with the RX. If you're not feeding power to the motor, it won't run. What do the ESC LED's show when the motor is running but you're not giving any throttle?? | |
10-02-2013, 07:00 AM | #8 | |
10-02-2013, 07:13 AM | #9 |
Double check and see what the LED's on the ESC show. You "may" just need to recalibrate the ESC to the RX.
10-02-2013, 07:25 AM | #10 | |
Thankfully i've got plenty of spares, I just hate to send back my good stuff :( I will just have to put a lot more thought into what i'm doing in the future. It's definitely a good learning experience! | |
HH Torquemaster Expert 35t hanging up. - Similar Threads | ||||
Torquemaster expert 13t vs crawlmaster pro 13 vs torquemaster pro 27t | cooperDG123 | Electronics | 6 | 05-08-2013 12:30 PM |
TorqueMaster Expert motor question | TLT-ROCKER | Electronics | 7 | 12-11-2012 05:34 PM |
TorqueMaster Expert 540 | ickabob | Axial Wraith | 0 | 11-26-2011 09:38 PM |
Non Official TorqueMaster Expert release | JohnRobHolmes | Electronics | 6 | 06-25-2011 09:27 AM |
