Thread: Micro Deans for Motor Connection On Crawler.
Old 10-06-2013, 08:39 AM   #1
Default Micro Deans for Motor Connection On Crawler.
Got me a pair of Castle sidewinder Micro's for my XR10 and plan on wiring with 18 gauge wire. Question I have is can a guy use the Micro Deans for the motor connections rather than a straight solder to the motor or regular Deans?
jaloos is offline   Reply With Quote
Old 10-06-2013, 08:53 AM   #2
Default Re: Micro Deans for Motor Connection On Crawler.
I have used them on several applications as motor disconnects myself. They work fine. You're not pulling that much current that you need to worry about them restricting power or burning up....at least I havent had any issues.
redsawacs is offline   Reply With Quote
Old 10-06-2013, 09:13 AM   #3
Thanks for the reply. Didn't think it was much of an issue but never hurts to find out what others have done and if it went well for them or not.
Old 10-06-2013, 11:06 AM   #4
I have used them without issue as well. I have since removed the micro deans for the mini-t plugs.. the ones in the middle.. a little more robust and way easier to plug together.. cheaper too.. 10 pairs for 3$ at HK...
winnerone23 is offline   Reply With Quote
Old 10-06-2013, 11:07 AM   #5
I run them to all my motors and now all my batteries as well..
Old 10-06-2013, 11:59 AM   #6
Thanks man, got a link for those can't seem to find them.
Pretty sure they are on the Team Brood web store as well but I doubt they are 3 bucks for 10 pair.
Old 10-06-2013, 12:19 PM   #7
Found em.
Micro Deans for Motor Connection On Crawler. - Similar Threads
Deans for motor connection? jbsmith05 Axial AX10 2nd-gen 9 04-05-2013 03:23 PM
bad motor connection subrosarider Electronics 1 03-05-2012 05:01 PM
help with micro deans.... pugs2300 Electronics 7 01-11-2012 11:36 AM
micro deans mike267 Losi Micro-Rock Crawler 6 03-25-2010 11:46 AM
