tekin 17.5 trun in wraith kit is it be ok in a wraith and there esc like rs pro? |
Re: tekin 17.5 trun in wraith kit Yes it will be ok, but will require lots of drive trane upgrades in order to be reliable and not break all the time. Just a personal preference, but I like the mamba max pro way more than the tekin rs or rs pro. |
Re: tekin 17.5 trun in wraith kit I ran a 17.5t/rs pro in a wraith for a bit. I wasnt overly impresed. It was slow and didnt have the precise control like a brushed motor does but it wasnt stupid fast like a BL wraith on 3s should be either. I went to a 13.5t and it was way faster and still had enough torque to backflip off rock faces |
Re: tekin 17.5 trun in wraith kit IMO the 2 best brushless crawler/basher motors on the market are the Tekin Pro4 3300kv and the Roc412. Next would be the Tekin Redline 13.5t. |
Re: tekin 17.5 trun in wraith kit Quote:
You don't use a high turn motor to get high speed on low voltage, you use it to get high efficiency and high speed on higher voltage! |
Re: tekin 17.5 trun in wraith kit the lhs told me rx 8 with a pro 4 3300 or 412 roc motor |
Re: tekin 17.5 trun in wraith kit I cant find anybody local that has the roc 412 in stock |
Re: tekin 17.5 trun in wraith kit whats good esc that will fit in the truck on the mount? |
Re: tekin 17.5 trun in wraith kit mmp |
Re: tekin 17.5 trun in wraith kit mmp with tekin roc 412? |
Re: tekin 17.5 trun in wraith kit Yes. MMP and ROC412 or Pro4. Either are great motors. |
Re: tekin 17.5 trun in wraith kit whats the shaft size on the 412 motors |
Re: tekin 17.5 trun in wraith kit 5 mm ? |
Like I said, 1/8". Quote:
