10-05-2013, 07:06 PM | #1 |
Rock Crawler Join Date: Jan 2013 Location: San Diego
| Fxr pro on 3s?
I have a Tekin FX-r pro in my scx10, with the stock 27t. The specs say to only run it with a 35t or higher mother. I want to use a 1300 mah 3s. I don't understand how the regular fxr has a 13t limit on 2s while the fxr pro doesn't have a limit, but the 3s limit is the same. What is causing the limit? I saw a upgrade for the capacitor to run up to 4s, so is the capacitor the reason for the limit? Please help! |
10-05-2013, 07:09 PM | #2 |
Rock Stacker Join Date: Aug 2012 Location: mchenry
I ran my fxr on 3s and a traxxas 21t 550 with no problems. Just make sure you run a bec on 3s and up. You can also upgrade the cap for 4s use if 3s aint enough.
10-05-2013, 10:45 PM | #3 |
| Re: Fxr pro on 3s? A 21t 550 motor is more in the 540 motor 30-35t speed range. So 3s should be fine. But as said above, I'd install a bec and 4s cap.
Fxr pro on 3s? - Similar Threads | ||||
Tekin FXR and FXR-pro ESCs in stock | JohnRobHolmes | Holmes Hobbies | 35 | 09-17-2009 09:40 PM |
