10-14-2013, 04:39 AM | #1 |
Newbie Join Date: Jan 2013 Location: Australia
| Sidewinder "Power On Warning Beep " ?
I just finished smashing together 2 micro Sidewinders, a CC BEC and Futaba receiver. It is all working well except when I use the front dig I am sometimes getting a small blip of power to the rear motor, anybody else had this issue ? I am now wondering if it is related to the "Power On Warning Beep"setting, I left it enabled( default setting) but thinking maybe it should be off, a bit of a pain to get to the unit now as its deep in a Chaotic Zero frame and I shortened the leads alot. Looking for advice before I dive in. Thanks Dave |
10-14-2013, 04:58 AM | #2 |
| Re: Sidewinder "Power On Warning Beep " ?
1-Did you recalibrate the ESC's to the RX? 2-The beep has nothing to do with the blip. |
10-14-2013, 05:46 AM | #3 |
1-Did you recalibrate the ESC's to the RX? Yes 2-The beep has nothing to do with the blip. New to brushed electrics but I know with brushless quite often the start up tones are generated by the motor ( my understanding anyway ) Just looking for ideas, would recalibrating again help ? |
10-14-2013, 09:12 AM | #4 |
No ESC, that I'm aware of, have a speaker in them, they all "ring the motor" to make sound. This is why there is no sound with a bad motor/brush or no motor connected. Recalibrating shouldn't hurt anything. Do both ESC's have the same firmware version & programming in them? Are the motors "MOA matched set"? The timing will be different for each motor since one is reverse rotation. |
10-14-2013, 04:23 PM | #5 |
That is what I was thinking with the bell ringing maybe causing the blip, I think I will disable it anyway if recalibrating doesn't work. I calibrated them individually the first time, is it OK to calibrate with them both plugged in ? Motors are Holmes Hobbies Torquemaster Sport 45t, not a matched set. I did wonder about the timing with one running reversed. Firmware is the same in both but I remember if I went with 1.24 or 1.28 , it was a while ago that I did that. |
10-14-2013, 04:54 PM | #6 |
I use V1.28 in my CC ESC's, there are some decent newer versions, but I like what I have. I do the profile programming in one ESC, then copy it and move to the other ESC. I usually calibrate both at once, some people have issues with that and need to do them one at a time. Yes, you need to check motor timing, they are both "timed the same" but one is advanced while the other is retarded. |
Sidewinder "Power On Warning Beep " ? - Similar Threads | ||||
<iframe width="420" height="315" src="//www.youtube.com/embed/gYr-dbPEOnE" frameborde | boolean21 | Scale Videos! | 0 | 10-01-2013 09:39 AM |
Is the Tekin B1R "low power in reverse" issue fixed? | GWEEDZ | Electronics | 3 | 05-27-2011 12:50 PM |
