Sealing my reciever Just checking to see if anyone has installed the leads and dipped or completly sealed the reciever then cut the leads and installed mini deans connectors so you could program the BEC and speed control? I dont know if the deans connections would be afected by water or not? |
I usually just put everyrhing in the rx box these days with extensions in them and seal it with amazing goop or shoe goo will do the same. This allows ne to reprogram everything and not have to break open the box unless a part gives out. I like my stuff to plug and play. I even put an inline extension on the bec to remove it completley and replace if need be, no direct soldering. Plug and play. Plug and play. Thanks, ORK |
Re: Sealing my reciever for my scale truck I decased my RX and from the bottom up I used plasti-dip to coat it up to the pins the plugs go on and bout 1/4" of the antenna wire "thumbsup" .... |
Re: Sealing my reciever Thanks for the replys. I have everything dipped in corrosion x now. Just thinking about a different way. I have not got to run to much wet stuff with this stuff. |
