10-20-2013, 06:30 PM | #1 |
Newbie Join Date: Jan 2012 Location: Trenton, Ont, Canada
| Faster backward.
I drive an old-school Axial AX 10 and for some reasons it goes faster backward than forward. Any suggestions as to why? I'm running a Novak Rooster crawler speed control and Novak 55 turn motor with an 87 tooth spur and 24 tooth pinion. Any thoughts would be much appreciated.
10-20-2013, 07:12 PM | #2 |
| Re: Faster backward.
All esc's are set up this way out of box.
10-21-2013, 12:34 AM | #3 |
Pebble Pounder Join Date: Aug 2011 Location: NSW, Australia
Is the motor timed correctly. If its timing is retarded then it will run faster in reverse than forwards (and also die very quickly if you keep running it with retarded timing). Have you mirrored your trans or flipped the skid at all at some stage?
10-21-2013, 03:16 AM | #4 |
| Re: Faster backward. I haven't done anything to the trans or the skid plate. As for the timing of the motor it is set up the way it came from the factory so l assume the timing is correct.
10-21-2013, 06:08 AM | #5 |
RCC Addict Join Date: May 2013 Location: York, PA
| Re: Faster backward. |
10-21-2013, 07:40 AM | #6 | ||
| Re: Faster backward. Quote:
Some ESC's come with a "50% speed" in reverse as stock. Most ESC's can change that setting. Read up on yours. | ||
10-21-2013, 12:47 PM | #7 |
10-21-2013, 01:14 PM | #8 |
Rock Crawler Join Date: May 2011 Location: SoCal
I've got a high dollar Brood on a BRXL that does the same thing. Eddie even had me send him a photo to convince him I had the timing set right. Still waiting for Matt to explain his statement. If the esc is intentionally set up that way, that would certainly explain things. But why would esc's be designed like that? |
10-21-2013, 01:50 PM | #9 |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
Sounds like some setting got changed on the radio. Double check your throttle setting.
10-21-2013, 02:20 PM | #10 | |
RCC Addict Join Date: Dec 2006 Location: Oak Ridge, TN
When you put the motor in did you have to reverse the throttle channel or swap the wires on the motor to get it to go in the right direction? It's most likely the timing on the motor or a setting in the ESC/TX that's causing the problem. Last edited by SINister; 10-21-2013 at 02:22 PM. | |
10-21-2013, 02:51 PM | #11 |
It's the timing of the motor. It needs to be advanced in forward to spin a little faster.
10-21-2013, 11:05 PM | #12 |
Rock Stacker Join Date: Aug 2013 Location: Colorado springs
| Re: Faster backward. well, you know what they say, to assume makes an ass out of you and me! there are sometimes mistakes so definitely check it. even out of the box.
10-22-2013, 05:51 PM | #13 |
I will check the timing on the motor. I will try and reset the speed control first . Thanks for the help thus far. I really hope it works.
10-23-2013, 04:40 PM | #14 |
It was as simple to fix as re-setting the speed control. I did it last night and now my truck is equally fast in forward and reverse. Thanks for all the help. Much appreciated!!
Faster backward. - Similar Threads | ||||
backward steelies | z71baja | Tires and Wheels | 0 | 05-24-2012 09:49 PM |
Backward Servo | BMFOTP | Electronics | 4 | 05-11-2009 09:13 PM |
making wk run backward | DARKSCOPE001 | HPI Wheely King | 9 | 01-25-2008 04:02 AM |
Claws forward or backward??? | scrotsbiz | Tires and Wheels | 19 | 01-18-2008 09:47 AM |
Running truck backward!?!?! Flipping the trans??? | RXcrawler | General Crawlers | 12 | 05-06-2004 10:18 AM |
