10-20-2013, 09:52 PM | #1 |
Rock Stacker Join Date: Aug 2013 Location: Gallatin
| Looking for a good lipo battery
I have a scx10. It's got all the orginal plugs taymia plugs I think there called. I need to know how to convert it to run lipo. It has a 7.2 v 5000 mah it's a nimh battery. If anyone could give me a good link to the battery and the plugs I'll need it would be greatly appreciated thanks a lot.
10-20-2013, 10:54 PM | #2 |
RCC Addict Join Date: Jul 2008 Location: San Diego
| Re: Looking for a good lipo battery
What speed control? Do you have a lipo charger?
10-21-2013, 08:04 AM | #3 |
Yeah I have a 230 duratrax charger says it charges lipo and nimh and some other ones lol.
10-21-2013, 08:10 AM | #4 |
Pebble Pounder Join Date: Mar 2013 Location: Albuquerque
have your local hobby shop solder on a better plug, Deans or Traxxas. SPC has some great batteries that can be ordered with either plug. you also need to turn on lo voltage cut off on ESC, buy a lipo safe sack and do a bunch of reading on all the rules of using lipo, they are not like other batteries. |
10-21-2013, 08:25 AM | #5 |
Pebble Pounder Join Date: Jan 2013 Location: avondale
I just found these at Lhs around 40 $ each good c rating 65/ 100 should give some good punch ! https://www.aero-model.com/4_158/Bat...eries-65C.html https://www.google.com/url?sa=t&sour...acHGKC4qbL-F3A http://www.axialracing.com/blog_posts/787000000 Assuming your rig is a stock rtr Last edited by azwheelman; 10-21-2013 at 08:43 AM. |
10-21-2013, 10:17 AM | #6 | |||
| Re: Looking for a good lipo battery Quote:
Fine. Here's what you're going to buy: Two of these two of these This connects your charger to your battery This replaces the white connector on your ESC and since your charger doesn't have an internal balancer Here, Just have your local hobby shop put those connectors on your ESC, and have them turn on your Low Voltage Cutoff, and you're all set. Easy-peasy! . | |||
10-22-2013, 07:27 AM | #7 |
Hey man I really apreciate then info sorry I kepted asking I was just confused. You put it out right lol. Instead of buying 2 batteries can I just get a bigger mah? So it'll last longer?
10-22-2013, 07:35 AM | #8 |
Pebble Pounder Join Date: Apr 2013 Location: Charlotte, Mi
| Yes, mah=how long it will last but also = larger size/weight in most cases. For a crawler 2200mah is a good balance between runtime and weight/size.
10-22-2013, 10:18 AM | #9 | |
Or THIS would allow you to connect two battery packs to the same ESC in parallel, effectively making those two 2200mAh packs into a 4400mAh pack. (Packs need to be the same voltage and nearly the same in mAh, though.) One'll work fine, I guess in these crawlers I have come to like the littler packs because you have more options on where to place them. A big pack's only going to fit in pretty much one, maybe two spots. Sorry if the previous post cam across a bit snide. Didn't take the time to properly word it as I was well on my way to being late for work and hadda get out of the ho........ Ho! Hallo! See ya latr | |
10-22-2013, 12:22 PM | #10 | |
Even with the battery(s) having a claimed equal rate (discharge/Capacity) Isn't there a possibility that the weaker of the two batteries could draw from the other battery and possibly damage either battery when being discharged, combined on a regular basis ? In other words... there is no regulator that controls output (discharge rate) of each individual battery. So they may discharge unevenly or even back flow into the weaker batt. (yes or no) ? I don't really know this rc elect. stuff too good... so that is why I'm asking for clarification. I'll assume each individual battery need be re-charged individually ? yes ? How is the ESC's LiPo cut off set for this combination ? ^ (auto, (2s or 3s respectively) I have dual batteries on my 1:1... It requires an isolator so that one battery cannot draw from the other. Regardless of whether they are charging or discharging. How is this different then combining AGM 1:1 batteries ? thank you for a response/clarification regarding. | |
10-22-2013, 12:53 PM | #11 |
Rock Crawler Join Date: Jan 2008 Location: Essex, UK
I bought some SPC lipos and have been really pleases with them.
10-22-2013, 01:30 PM | #12 | |
| Re: Looking for a good LiPO battery Quote:
Yes, charge them by themselves. No, running 2 packs in parallel is not any different than running multiple cells in a pack (series connection). Each cell/pack has it's own "personality", thus behave a little different. You could do a diode to prevent one pack from charging the other, but not likely really worth it. [PS, "AGM" = "Absorbed Glass Mat" which is a common term for sealed/spill proof or maintenance free lead acid batteries used in 1:1 rigs. I work in the "large UPS" world, spend a lot of time with VRLA/AGM batteries.] | |
10-22-2013, 02:31 PM | #13 |
It's all good man thanks for the info I ordered what you said. Appreciate it tho.
Looking for a good lipo battery - Similar Threads | ||||
What Zippy Lipo battery fits a Crawler King? Or whats your favorite 2c lipo battery? | phunkodelic | HPI Wheely King | 20 | 08-31-2009 01:35 PM |
Best Charger for Lipo batteries, and best lipo battery | phunkodelic | Electronics | 12 | 06-14-2009 10:58 AM |
Is this a good Lipo battery (rhino and zippy)? | Flatty | Electronics | 3 | 08-24-2008 10:48 PM |
