10-22-2013, 01:51 PM | #1 |
Pebble Pounder Join Date: Jun 2012 Location: Lucerne Valley
| Sevro Winch Choices
Going to set up a sevro winch and not sure what one would make a good choice. How much torque should you use ( usually more is better? ) and what for the speed, faster line draw would be best? It sound like I'm answering my own questions, but what are you guy's using? On a budget or I would find the one with the highest torque and the fastest for line speed. Already search on the forum but couldn't find the answer I was looking for. Thanks J. |
10-22-2013, 02:24 PM | #2 |
RCC Addict Join Date: Dec 2006 Location: Oak Ridge, TN
| Re: Sevro Winch Choices
The more power a servo has the less likely it is to fail. If you're not on a budget the heyok winch and controller combos are really nice. A buddy has one on his 10lb rig and it pulls with no problems. I'll pick one up eventually but for giggles I built one out of an old 645 servo and $1.50 worth of parts from radio shack. So far it pulls my 5lb scx10 around with no problems.
10-22-2013, 02:48 PM | #3 |
I'm using cheapie towerpro/towardpro servos @7.2v for winches, they easily dead lift both my ~7lb scalers and have decent line speed. Next ones when these die will be some cheapie hv solar servos at 9v. Get what your budget allows, only step up from a traditional servo winch would be a k3 or quicksand. |
10-22-2013, 03:00 PM | #4 |
both of mine are dead Savox servo's with 360oz @ 6v with Heyok controllers. Total overkill for a servo winch but much better than leaving them sit in a drawer. Line speed is kinda tricky. You want it to move fast when unspooling but slow when winching so you can control it. I use a Rogue Elements snatch block to slow mine down, as well as double the strength. |
10-22-2013, 03:40 PM | #5 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
HeyOK ....can't go wrong
10-22-2013, 03:51 PM | #6 | |
10-22-2013, 04:06 PM | #7 |
| Re: Sevro Winch Choices It'd be impossible to run both the truck and winch at the same time, imo, but it'd be really cool to hook the winch up to the throttle of a 2nd radio.
10-22-2013, 06:15 PM | #8 | |
| Re: Sevro Winch Choices Quote:
Will also be using the Heyok controller. I have a couple sevros I'll look up the torque specs. on them. Thanks J. | |
10-22-2013, 06:53 PM | #9 |
Quarry Creeper Join Date: Sep 2005 Location: Geneva, FL
I use a HeyOK servo winch and I'm more than pleased with it. My truck weighs around 10-11 pounds and it works like a charm with no issues.
10-23-2013, 08:45 AM | #10 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| Re: Sevro Winch Choices |
10-23-2013, 08:54 AM | #11 |
| Currently running rtr esc's as winch controllers with the 3rd channel of a hacked gt3c, however it's only 3pos and not variable. Been curious about harvesting only the ch1 steering mechanism and elecs. To run a higher voltage for the line speed out and controllability of line speed going in. But like johnnyh66 said, would probably be a bit cumbersome.
10-23-2013, 09:13 AM | #12 |
I wanna be Dave Join Date: May 2010 Location: The east coast
are you looking to have the winch controlled via radio? if not there is a pretty cheap way of doing it. heyok () drew up a simple two switch setup for a hoist i put on my rig (see around post 59 in my build thread for reference jebster's 6x6). i just took the internals out of the servo, added the switches and plug in the power. works great for me but it does have to be operated at the truck. |
10-23-2013, 11:05 AM | #13 | |
Using hacked gt3b.... Step rate and return to center on d/r. I'll post up my setting if I get a chance this week | |
10-23-2013, 11:02 PM | #14 |
11-19-2013, 01:13 PM | #15 |
Quarry Creeper Join Date: Aug 2011 Location: Antioch by a rock!
Just mounted up my servo winch using the BPC battery tray in my 10LB Wraith. Servo is a Solar D772 with Heyok controller and GT3C hacked. I did several like 15 dead pulls of 10LB at 11 volts and no heat issues. I think I'll keep it there for now. I have several D772's laying around so no big lose if it burns up.
11-19-2013, 01:26 PM | #16 |
Rock Stacker Join Date: Aug 2013 Location: Calgary
I used a 645MG. Stripped out all the guts except motor and gears, and used an old brushed ESC to control it. It'll lift my SCX10 vertically no problem, even at the lowest speed.
11-19-2013, 02:39 PM | #17 | |
11-19-2013, 03:06 PM | #18 |
Thanks meat. Can't wait to use it inn a real comp.
Sevro Winch Choices - Similar Threads | ||||
Steering sevro problems | Slap204 | Axial Wraith | 4 | 12-28-2011 01:06 AM |
MRC scale winch choices? | foodstick | Losi Mini-Rock Crawler | 0 | 01-17-2010 10:58 AM |
So Many Choices | JatoTheRipper | Newbie General | 24 | 10-20-2008 02:35 PM |
Sevro list | badtodabone | Electronics | 0 | 02-27-2004 07:34 AM |
