10-23-2013, 01:07 PM | #1 |
Rock Stacker Join Date: Aug 2006 Location: Boone, NC
| CC sidewinder V3
Picked one up for my CC01 build. I have read in a couple threads here to roll back firmware to a version prior to the "crawler reverse" setting. I am on latest firmware, and crawler reverse seems to function pretty well. Drag brake is on "full on", and reverse is without delay. Am I missing something by not rolling back firmware? I'm sure this has been covered, but a search didn't turn up much. Thanks! Jason |
10-23-2013, 01:38 PM | #2 |
RCC Addict Join Date: Dec 2006 Location: Oak Ridge, TN
| Re: CC sidewinder V3
Sometimes if you have problems setting up the esc rolling back the firmware can solve the issue. Never heard of rolling it back past crawler reverse though. Personally I think some of them come from the factory with corrupted firmware and just reloading a different version fixes it. If you don't have any problems then don't worry about it |
10-23-2013, 04:34 PM | #3 |
I don't seem to be having any problem. HUGE improvement over the stock ESC! All my other ESC's are BL only, and I wanted to stick with a brushed motor in this truck. I should mention, I'm running this on a little A123 pack. Not sure if I should set the cutoff to the minimum 3v per cell (too low for A123, really), or just leave it off.
10-23-2013, 10:56 PM | #4 | |
| Re: CC sidewinder V3 Quote:
I run firmware 1.28(?) with no issues. I have read there are some newer versions that fix some glitches that messed up crawlers. I have not tried them though so can't comment based on personal experience. | |
10-24-2013, 09:55 AM | #5 |
Thanks, guys. Seems to be running great so far. Just had to bump the reverse up from 50%. It was cutting out a bit until I set the LVC to custom 5v. 2.5v per cell should be fine for A123 cells. I have an external 6v BEC on there, but I am thinking about wiring the servo direct to the ESC power leads. The 6.6v nominal pack voltage should be fine for a servo, don't you think? Thanks again! |
10-29-2013, 07:46 AM | #6 |
| Re: CC sidewinder V3 Castle Creations ESC tip thread(brushed) That's the thread I was talking about that references the older firmware version. |
CC sidewinder V3 - Similar Threads | ||||
sidewinder and sidewinder SCT troubleshooting | nstn8 | Electronics | 7 | 01-17-2011 07:50 PM |
sidewinder with a cc bec,works great but Can I swap it out for a Micro sidewinder? | username | Electronics | 3 | 04-04-2009 10:11 PM |
sidewinder/sidewinder micro/mamba 25 | nj05nismo | Electronics | 2 | 03-07-2008 08:42 PM |
