11-01-2013, 08:12 PM | #1 |
Rock Stacker Join Date: Mar 2009 Location: Tacoma
| Traxxas ET-3S is basically te same as an MMP
Except its limited to 3S input. They sell for $60 or less on ebay. I have been using one in brushed mode and I hear it works fine on brushless sensored motors.
11-02-2013, 06:33 AM | #2 |
Rock Crawler Join Date: Dec 2005 Location: East Texas
| Re: Traxxas ET-3S is basically te same as an MMP
Yeah, that's been around awhile, and its been known to handle 4 and 5s as well. Haven'theard of 6 but don't see why it wouldn't being it has Lipo cutoff to 6s as well.
11-02-2013, 10:52 AM | #3 |
didn't know that, thanks for the heads up, i will be looking for them on the bay |
11-02-2013, 12:17 PM | #4 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
can someone post up pics of the castle link software confirming the crawler drag brake settings.
11-02-2013, 01:54 PM | #5 | |
| Re: Traxxas ET-3S is basically te same as an MMP Quote:
Wonder if a CC link will work on it. While I love CC ESC's (as well as Holmes Hobbies ESC's), I'm curious to see if there is an equivalent ESC for a lot less money. | |
11-02-2013, 02:17 PM | #6 |
Quarry Creeper Join Date: Jun 2012 Location: Next to you
I did a google search about it and there is some good things about it. I didn't find anything about drag brake but that doesn't mean it's not there. Some say only 3s only but for me that's fine. I going to do some more searching but looks like I might be selling my sidewinder sv3 for this.
11-04-2013, 09:44 AM | #7 |
Quarry Creeper Join Date: Jun 2012 Location: Earth mostly
| Re: Traxxas ET-3S is basically te same as an MMP |
11-04-2013, 09:59 AM | #8 |
This might be the best esc for the money bar none if you do not mind 2s-3s. Short course esc for sure,
11-05-2013, 08:12 AM | #9 |
Newbie Join Date: Jun 2011 Location: Vienna
Anyone using the Traxxas ET-3s with a sensored brushless motor and drag brake?
11-05-2013, 11:43 AM | #10 |
I ran it brushed with a 27T HH HW. It did fine. I swear it had the crawler drag brake setting. Haven't tried BL. Its sitting in my box. Swapped it for an SV3 for the waterproof aspect. May go back to it and move the SV3 to my SCX10. I have too many ESCs and can't make up my mind. |
11-05-2013, 08:02 PM | #11 |
I run 2 ET-3S speed controllers. One is in a Wraith with a Tekin 412 3100kv that runs 2S most of the time but 3s on occasion. I don't have full drag brake set, but run it about 30%. I run a second ET-3S in an SCX with a 13.5t stock motor on 2s. They are nice ESC's, unfortunately the price has jumped recently because people have figured out that they are a rebranded MMP.
11-05-2013, 08:06 PM | #12 |
As far as the max voltage, the capacitors that are on the ET-3S look like they are the limiting factor. If you swap them out I'm sure it will run fine. Or, run it like that and when they pop just replace them with higher voltage caps.
11-05-2013, 09:27 PM | #13 |
I read where someone tried 6s and it wouldn't work. I'm afraid to try it on mine. I'm looking at mine now and it has crawler reverse and 213% crawler full on drag brakes. I used mine brushed with HH HW 27T worked great. I maybe using it with a Novak crawler motor in my wraith. I thought I would contribute |
11-10-2013, 02:59 PM | #14 |
OK I just put my Novak Ballistic Crawler 18.5 in my Wraith 2 Speed with the Traxxas ET-3S and all is fine. Running 3S, DB is at 70% but my point is that it will work with no hiccups.
11-11-2013, 07:48 PM | #15 |
This is great to know. Thanks for the heads up!
12-09-2013, 01:44 PM | #16 | |
Pebble Pounder Join Date: Feb 2011 Location: Northwich, England
I just got one of these to try out, plug it into my castle link and here are the results:- Not run it in anything yet but it definitely looks promising especially as it worked out at about £40 ($65) delivered to the UK. | |
12-09-2013, 01:49 PM | #17 |
Let us know how it works in your truck.
12-09-2013, 01:51 PM | #18 |
Rock Crawler Join Date: Jan 2013 Location: Middleburg Florida
Yep I just got one. It does everything a full MMP does except go over 3S on battery. It won't arm on 4s or bigger. If we could figure out a way to update the OS to a normal MMP OS it would probably do 6S.
12-09-2013, 03:32 PM | #19 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
Rumor has it, the sensor port works also
12-09-2013, 05:14 PM | #20 | ||
| Re: Traxxas ET-3S is basically te same as an MMP Quote: Quote:
Yep, in the 1st linked thread...... but you knew that. | ||
Traxxas ET-3S is basically te same as an MMP - Similar Threads | ||||
Traxxas slash 4x4 ultimate with a MMP but which kv motor? | axial 4x4 crawler | Non Crawler RC's | 20 | 07-10-2013 11:31 PM |
Old MMP paired with a traxxas vxl motor? | Tgreer | Electronics | 3 | 06-24-2013 10:24 AM |
