Thread: Holmes Hobbies br-xl waterproof in quiet mode
Old 11-06-2013, 03:25 AM   #1
Default Holmes Hobbies br-xl waterproof in quiet mode
Ok I am checking out the settings on the HH brxl esc and when I turn on the quiet mode my steering servo glitches when turning slow, turning fast no glitch. Turn the feature off and steering as normal returns. The servo, futaba s9452
realsickclown is offline   Reply With Quote
Old 11-06-2013, 07:36 AM   #2
Default Re: Holmes Hobbies br-xl waterproof in quiet mode
Yes, you need an external BEC!
hpiguy is offline   Reply With Quote
Old 11-06-2013, 08:28 AM   #3
Originally Posted by hpiguy View Post
+1
My Savox 1230SG did the same thing when I plugged it in directly. Wired it to the BEC and all is good.
maslin is offline   Reply With Quote
Old 11-06-2013, 08:43 AM   #4
That is already installed. So the next answer would be?
Old 11-06-2013, 08:47 AM   #5
Now this only happens in the "quiet mode" I turn off the "quiet mode" and the issue is fixed. I'm hoping John H. will chime in here.
Old 11-07-2013, 06:10 AM   #6
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
What radio and motor? The higher switching frequency causes more emf noise. Does it happen when sitting still?
JohnRobHolmes is offline   Reply With Quote
Old 11-07-2013, 08:44 AM   #7
It does not make any sound sitting still. Only while turning slowly in the "quiet mode" does it get glitchy,if Turing quickly it does not act the same. I just switched it off and everything went back to normal. My motor is HH torquemaster sport 27, the radio I'm using is a FlySky FS-GT3B.
Old 11-07-2013, 08:50 AM   #8
What is the fix then? Different servo? Hack my FlySky? Different radio all together?
Old 11-07-2013, 10:00 AM   #9
That is a 2.4ghz radio, so there isn't a good reason for the glitch. Filter caps on the motor and a small cap on the RX would be my first try, or another RX if you have one handy. Doesn't have to be much capacitance, .47uf or 4.7uf ceramic caps from radio shack would do the job.
Old 11-07-2013, 01:20 PM   #10
Mr John please check your storefront email as I have sent a couple regarding another issue I experienced. It could be the reason?
Old 11-07-2013, 01:59 PM   #11
I forgot I am using the stock AR-3 axial radio from my wraith, for testing when I was done building the chassis. It still is a 2.4 radio
Old 11-07-2013, 02:02 PM   #12
Try moving the RX and/or RX antenna away from the ESC & motor wires? That is where most of your RFI & EMI would come from.
Are your motor brushes arcing? The arcing creates a bunch of nasty "electrical noise" that messed with AM/FM radios, thus the need for caps. The same noise can potentially mess with 2.4ghz, although not as much of an issue.
Charlie-III is offline   Reply With Quote
Old 11-07-2013, 03:50 PM   #13
I do think that the way the motor sits it is to close to the not that holds the 4link/nerf bar but I can drive around just fine. I am going to try and turn on the "quiet mode" again and see if maybe I had some odd setting?
Old 11-08-2013, 02:43 AM   #14
Ok maybe I described my problem wrong, the steering is jumpy,twitchy but there off's no buzzing or glitching noise. The turing is twitchy/ jerky
Old 11-10-2013, 09:19 PM   #15
AddictedtoRC1's Avatar
Why not just keep "quite mode" disabled?
AddictedtoRC1 is offline   Reply With Quote
Old 11-11-2013, 08:46 AM   #16
I am, but I would like to use the feature. Plus I'd like know the the esc is working correctly. I ran 2 packs thru it yesterday and it ran great.
Old 11-11-2013, 11:21 AM   #17
I love Quiet mode, so I know why you want to use it.
You try caps on the motor or RX yet? I still haven't found a good reason for the problem, nor have I heard of it before now. I would need to put an oscilloscope on your system to see what's up.
What is your BEC voltage?
Old 11-11-2013, 03:11 PM   #18
BEC voltage,,that I do not know. I looked when I was using the castle link and did not see the option the to make adjustments in the software, do I have that option with the castle link? Or are you saying I need an external BEC with this esc, I was under the impression there was one onboard. Am I wrong?
Old 11-11-2013, 03:50 PM   #19
The first person in the thread said you need a BEC. You said you had one. Now you don't?
You need a BEC. Not the one built in to the ESC.
Old 11-11-2013, 05:38 PM   #20
ok so I went in and set the voltage cut off to 11.1 and now everything is working correctly. wow that was difficult.
Holmes Hobbies br-xl waterproof in quiet mode - Similar Threads
HH torquemaster quiet mode? spdyracer Electronics 6 09-19-2010 01:43 AM
