11-08-2013, 11:55 AM | #1 |
Quarry Creeper Join Date: Aug 2012 Location: Melbourne
| Wiring advise needed
I need to tidy my wiring in my wraith and need some help with it. I'm running an Mt 4 radio and 4 channel rx, CCBec, BRXL, 7950 servo (steering), cheap hitec for dig. I also want to start fitting lights to my rig. My install is as follows: TH: BRXL (red wire removed) ST: 7950 AUX1IG SERVO AUX2: CCBec (powered from esc battery wires near plug) Is there another way to maybe free up a port on my RX by using a Y-splitter or by rewiring the CCBec? What way should I power my lights as my CCBEC is wired at the deans and not sure if I can wire the light bar to it too... Any help is greatly appreciated! |
11-08-2013, 12:35 PM | #2 |
| Re: Wiring advise needed
Wire the CC BEC direct to the servo, let the ESC BEC power the RX (reinstall the red ESC to RX wire to the connector), lights & shift servo. PS, you can use a splitter to run external BEC power to the servo. In some radios (like Spektrum) they really want all the grounds (BEC, servo & RX) to be tied together. |
11-09-2013, 01:36 PM | #3 | |
Thanks ill do that! Any advice on wiring the light bar? Just solder it to the deans on the esc | |
11-09-2013, 03:02 PM | #4 |
Another option is to use a lighting controller that uses the throttle channel with a piggyback connector so it doesn't take up a channel. HeyOK makes several nice lighting controllers. HeyOK's RC Electronics items (all in one place) |
Wiring advise needed - Similar Threads | ||||
1.9 Tire Advise Needed | Bananaclip | Tires and Wheels | 10 | 03-07-2011 08:26 PM |
Drivetrain advise needed | Bananaclip | General Scale Talk | 1 | 12-12-2010 06:22 PM |
** Advise Needed ** | 73formulabird | Newbie General | 2 | 04-12-2010 07:10 AM |
Advise needed? | Bananaclip | Electronics | 1 | 04-05-2009 04:39 PM |
NEWB - Advise needed | Yeeharacing | Newbie General | 7 | 11-12-2007 01:33 AM |
