03-15-2007, 07:15 PM | #21 |
Your master ESC would probably do the job, but I dont know how the reverse action is. I never owned one. I would suggest a Hyperion z3025 or similar outrunner for that beast. The Hacker 3025 is the same motor.
03-15-2007, 07:30 PM | #22 |
Newbie Join Date: Feb 2007 Location: Tonsberg, Norway, Europe.
Thanx for a swift answer Well I'm kinda looking for a new ESC to go with my crawler-project. I'm not too happy with the Hacker-ESC's... The motors from Hacker are great, but the ESC's is somewhat goofy. What ESC would you recommend?? Thanx again!! Regards Roy. |
03-15-2007, 07:48 PM | #23 |
Hands down the mamba max is the most flexible, affordable, and capable right now.
03-15-2007, 08:02 PM | #24 |
Ok, then Mamba Max it will be. I can't seem to find any Hacker 3025... You mean the A-series, don't you?? And what about the JETI BL Advance Car Sport ESC?? http://www2.towerhobbies.com/cgi-bin...?&I=LXNHA8&P=7 Regards Roy Last edited by TheWiking; 03-15-2007 at 08:11 PM. |
03-15-2007, 08:11 PM | #25 |
Find a Hacker 30 series that is 6 ounces or more and you are golden. a30-8xl would be my choice. I forgot they changed the name to something that doesnt actually describe the size of the motor other than "L" and "XL"
04-06-2007, 12:00 PM | #26 | |
Newbie Join Date: Mar 2007 Location: Finland
04-17-2007, 03:31 AM | #27 |
Newbie Join Date: Dec 2005 Location: The Fort
I'm tring to find out what brushless set up to run in my 1/6 scaler. Right now Im running a moped esc, 55 turn axle snappers, 2 tp mg 995 servo's and 3000 mah nihm batteries. The tires and rims are Nylint. It has a steal frame, and a hard body. I would guess 20 pounds, Its a heavy one. I want to run lipo's, I have been looking at the revolvers, but I think thay would be too small. I think a set of mamba max's would work for escs, but Im not sure on the motor. The way it is right now I get about half an hour to 45 min.s of run time( just playing on the rocks in the backyard. This was my first RC, and I built it from scatch. Thanks for any kind of help Wes |
04-17-2007, 11:09 AM | #28 |
| A stock silver can will have more grunt off the line and weigh 3x as much. Once the smaller motor gets spooled up it will have close to the same power.
04-17-2007, 11:10 AM | #29 | |
I would think that an outrunner of the 3025 size would be enough, especially if you had pretty low gearing. Do you have a build thread? | |
04-17-2007, 11:50 AM | #30 |
09-17-2008, 08:19 AM | #31 |
Quarry Creeper Join Date: May 2005 Location: Between rocks and hard places
How can I tell if it will have the standard mounting dimensions and won't need an adapter plate? I was looking at some of these Turnigy motors. For the price they look worth trying once. Turnigy Motors |
