11-17-2013, 12:09 AM | #1 |
Rock Stacker Join Date: Mar 2009 Location: Tacoma
| Help! Why is my MMP way faster in reverse?
So when I go forward the ESC lights up green. So I know its going forward. In reverse its faster than heck. EPAs are at 100, Power is set to 100. A is to A Bis to B and C is to C. Cant figure it out. I'm running a 13.5 Novak in a 2 speed wraith.
11-17-2013, 12:18 AM | #2 |
Rock Stacker Join Date: Aug 2013 Location: Calgary
| Re: Help! Why is my MMP way faster in reverse?
What's the motor timing at? Did you calibrate to your radio?
11-17-2013, 12:22 AM | #3 |
Its at 0. Its a Novak Ballastic Crawler Motor.
11-17-2013, 08:27 AM | #4 |
Quarry Creeper Join Date: Apr 2006 Location: canada
i had a similar problem recently use the castle link and reverse the esc it worked in my case and it went from reverse wheelies to forward wheelies
11-17-2013, 09:58 AM | #5 |
Quarry Creeper Join Date: Jun 2012 Location: Next to you
My MMP with PRO4 it also runs faster in reverse than forward. I think it does this because the motor in running in reverse. Not the normal way the motor usual rotation. If I wrong please let me know? Thanks
11-17-2013, 11:42 AM | #6 |
I just want to say when I mean faster I mean ballons the tires and straight gets it. What is weird is I swear it comes and goes. Everything seems to be as it should on the radio and ESC. I'm not a newbie, I've been doing this for years, its just my first time trying brushless in my crawlers. I'm suspecting maybe the ESC is just funky and I am going to slap in a sidewinder temporarily to see how that works. I have a Novak Crusher ESC with a Novak Ballastic 18.5 in my SCX10 and they are wired the same and its acting normal. So I am suspecting its the ESC. |
11-17-2013, 11:44 AM | #7 | |
Pebble Pounder Join Date: Feb 2013 Location: Charleston
| Re: Help! Why is my MMP way faster in reverse? Quote:
11-17-2013, 12:35 PM | #8 |
Did all that. I installed my sidewinder v3 and it was the same speed both directions BUT the speed was wasn't as fast as the MMP in reverse. On the SV3 I did have both forward and reverse set to 100%. So we can rule out all radio and mechanical motor timing settings for sure. I think my MMP is messed up. I like it but I think it is messed up. I had a little issue when field testing and accidentally hooked up my power to my CC BEC backwards. It fried the CC BEC and heated up the black wire on the receiver/servo harness of the MMP pretty good. I bench tested the MMP and all seemed well. I replaced the harness. Last night it seemed fine but one time I hit reverse and it flipped. It never did that before. SO I took it in and looked at the wiring and hooked it up to the computer and nothing. I tried reversing the radio, reversing direction & swapping A & C wire around. That last one caused some serious cogging. After swapping with a known good ESC I think my MMP is messed up and maybe adding gobs of timing or something in reverse? What ever it is, it's alot more powerful. |
11-18-2013, 08:52 AM | #9 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
Read the manual.... The ESC isn't messed up, Between your radio and ESC something isnt programmed correctly. |
11-19-2013, 05:03 PM | #10 |
Quarry Creeper Join Date: Feb 2013 Location: hawkins
mine did this with my pro4 i had to shut the cheat mode off and run sensor only
11-19-2013, 06:41 PM | #11 |
Pebble Pounder Join Date: Nov 2012 Location: springfield
you put your body on backwards and are really going forward sorry couldn't resist. I've had this happen a long while back if i remember right for me i just recalibrated the radio and it corrected it i think...or i reversed the motor from the controller
11-19-2013, 06:48 PM | #12 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
when running it..green led should be forward..red led reverse. if you pull the throttle for forward motion and it lights up red..wrong. hook it up to castle link and rev the throttle input. |
11-19-2013, 07:48 PM | #13 |
Newbie Join Date: Oct 2013 Location: SO-CAL
cant you switch two wires from the esc and motor around and switch the direction and then recalibrate radio.
11-19-2013, 08:07 PM | #14 |
| Re: Help! Why is my MMP way faster in reverse? |
11-20-2013, 06:37 AM | #15 |
RCC Addict Join Date: Mar 2011 Location: Katy / west houston
Did you try recalibrating your TX?? . |
11-25-2013, 05:13 PM | #16 |
Rock Crawler Join Date: Sep 2012 Location: Pasadena
11-25-2013, 09:09 PM | #17 |
Newbie Join Date: Oct 2013 Location: Kc
Dude. I don't mean to be a Debbie downer but I've heard scary bad things about Novak motors, sometimes they just won't spin up, sometimes the flip polarity, really sick s***. I hope you figure it out though, I would be inclined to say its the transmitter programming but I believe you when you say you have that all right. Good luck! Sent from my iPhone using Tapatalk |
12-02-2013, 02:53 AM | #18 |
| Re: Help! Why is my MMP way faster in reverse? The Novak motors have a built-in 15 degree timing that is by default negated in Novak's crawler ESCs. If your motor is running in its reverse direction when going forward you thus have a -15 degrees timing! Ideal is if you can rotate the tranny to have the motor run in the right direction. The other option is to add at least 15 degrees timing in the ESC. (I had the same problem with my motor, which can have no less than 15 degrees mechanical timing on the sensor.) |
12-03-2013, 12:09 PM | #19 | |
Rock Crawler Join Date: Oct 2009 Location: Knoxville
Well that just makes sense. | |
12-04-2013, 02:15 AM | #20 |
Correct. Net is 0 degrees going forward and 15 degrees while running in reverse (where the ESC is locked to 0 degrees).
Help! Why is my MMP way faster in reverse? - Similar Threads | ||||
reverse is faster? | EMUTT | Electronics | 11 | 08-13-2011 08:28 AM |
Faster in Reverse??? | whitejc4 | Newbie General | 10 | 01-17-2011 12:00 PM |
Is it really faster in reverse? | RickM | Axial AX-10 Scorpion | 3 | 02-10-2010 10:07 PM |
Faster in Reverse? | MtnBkr | Electronics | 10 | 01-23-2009 12:08 AM |
Faster in Reverse? | SpyderMonkee | General Crawlers | 2 | 03-17-2008 12:19 AM |
