Thread: LiPo 25c vs 50c
Old 11-17-2013, 09:23 AM   #1
Default LiPo 25c vs 50c
What does the 25c and 50c on LiPo packs mean and which one would be better for crawling?
Jeff@TireBalls is offline   Reply With Quote
Old 11-17-2013, 09:45 AM   #2
MODERATOR™
EeePee's Avatar
Default Re: LiPo 25c vs 50c
Google yo!
https://www.commonsenserc.com/page.p...explained.html
EeePee is offline   Reply With Quote
Old 11-17-2013, 09:46 AM   #3
So which one would be better for crawling?
Old 11-17-2013, 09:57 AM   #4
MODERATOR™
EeePee's Avatar
Without going into any type of explanation, most everyone will opt for the higher 50C battery over a 25C battery, no matter the vehicle.
Old 11-17-2013, 10:15 AM   #5
Good deal, that's what I ordered. Thanks EeePee!!!
Old 11-17-2013, 10:43 AM   #6
+1...... "C" ratings really come into play with smaller mah packs, if you're running ~2000mah or larger packs (regardless of voltage) "C" is a smaller deal.
The stickies at the top of this forum section will answer the rest if you want to read.
Charlie-III is offline   Reply With Quote
Old 11-17-2013, 10:53 AM   #7
The one that I ordered is 2s 5000mah
Old 11-17-2013, 11:35 AM   #8
Mah and C ratings go hand in hand, as was mentioned in the article EeePee posted. A 2s5000mah20c pack will net 100amps discharge, which is more than enough for crawlers IMO. Also IMO that pack is very large physically for a crawler. The discharge should only be worried about on smaller packs, as Charlie mentioned.
Meatwad is offline   Reply With Quote
Old 11-17-2013, 11:43 AM   #9
A 20 to 30C pack is plenty for crawling. 40C and above is good for racing on and offroad, aircraft, and boats.
Johnnysplits is offline   Reply With Quote
Old 11-17-2013, 11:49 AM   #10
...depending on capacity. For instance, an 800mah pack would be better at 40c or higher. Whereas a 5000mah pack can do ok at 20c.
Old 11-17-2013, 12:02 PM   #11
That's true. I don't have any lipo's less than 2200. But I guess for a comp crawler, you need small, lightweight lipo's.
Old 11-17-2013, 12:09 PM   #12
They do indeed, my smallest are 1300mah. I know of guys running 800 and less who need some stink for the crazy stuff those comp guys do.
Old 11-15-2019, 09:31 AM   #13
It looks like this link is dead... here's the updated link:
https://www.commonsenserc.com/page.p...education.html
jdtree is offline   Reply With Quote
LiPo 25c vs 50c - Similar Threads
25c lipo a bit much for a 1/24 scale crawler? spoo76 Losi Micro-Rock Crawler 9 01-22-2010 05:19 PM
Holmes Hobbies 25C 1300mah lipo? MtnBkr Electronics 8 03-20-2009 09:04 AM
